Need Help! I/S Broken Down
Started by X Ring, Sat 15, Jun 2013, 14:27:39
Previous topic - Next topic
X Ring
I'm at The Old Country Store Restaurant in Lorman, MS & my I/S has broken down. The starter is not engaging the engine. If anyone can help please give me a call at two two eight two zero nine four two zero three.
TIA,
Marty
Romeo
Not sure what your situation is Marty, but wondering if you could ask someone to push start her.
How old is the battery......low amps will do that, is there someone you can get jump from?
X Ring
Got home about a half hour ago. With advice from Warlock & ChrisJ357 I was able to get it started.  Also Warlock & Beekeeper were both coming to get us. I really appreciate that!
Marty
Fuzzy (Louisiana)
 :cooldude:  Yep, you can always count on Warlock (David) to lend a hand.
Fuzzy
1981 Honda Silverwing Interstate
1999 Honda Valkyrie Interstate
PAVALKER
So, inquiring minds would like to know what the issue was?  And what was done to correct it.
John
Quote from: X Ring on Sat 15, Jun 2013, 20:15:23
Marty
So what was the advice?
Warlock
Quote from: Britman on Sat 15, Jun 2013, 21:34:12
Marty
Bad spot in flywheel. Maybe past hydro lock. Once he got by the bad place was able for starter to work.
david
