1000lb HF lift. Dangerous design flaw.
Started by Chippy01, Wed 21, Aug 2013, 07:19:56
Previous topic - Next topic
Chippy01
I saw this on another forum; and thought I'd alert those that haven't seen this yet.
http://ngwclub.com/forum/viewtopic.php?f=13&t=48993
'98 GL1500C Standard Valkyrie
'88 VF750C SuperMagna
'89 GL1500 GoldWing
Fritz The Cat
Thanks for this. I was considering buying one, but not now.
#2944
I've been using this lift for several years now, never a problem.....  The bar in the picture is a screw up by HF, my bar would be closer to an inch, fills the hole snug and very strong.  Some one took a short cut on the lifts you got.....
Zots
Just ride it!
Tx Bohemian
Quote from: #2944 on Wed 21, Aug 2013, 09:07:31
Zots
Same here and I agree with the "short cuts"!!
I have the same bar as in the lower pictures and that poster noticed a different design in the framework as well.
Also I noticed the "new" lift in the picture don't have the cheesy front wheel clamp either. (which I changed mine out to the air/hydralic one soon after I got it, clamps the wheel much better and safer)
Our bikes weigh about 850# which is only 150# lighter than the max suggested capacity and I never had any problems.
And that's pitiful these guys paid $350 for that.  With a cupon from some cycle magazine I paid $279 about 2 yrs ago.
Al
olddog1946
I borrowed one of those HF lifts to do the clutch on my BMW K1200LTE and it worked just fine, but I did put jack stands under the lift table since my butt and the bike were over the limit.
You should also note that the lift was not put togther properly. Those side pieces are upside down. the L shape should have been on the top side, giving a wider plate for that safety bar to ride on.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
justintyper
Quote from: olddog1946 on Wed 21, Aug 2013, 16:51:30
i noticed that too although it looks like that part came preassembled so maybe the blueprints werent followed properly by whoever in china is making them now.... glad i didnt get one now.
markj #3467
QuoteLooks like the lower frame on yours is upside down compared to vintage GW pics.
He put it together wrong, the top is at the bottom in his bent rails. Maybe he should read the instructions better?
