What size is the valve stem
Started by BIG--T, Tue 03, Sep 2013, 14:57:38
Previous topic - Next topic
BIG--T
on the Valkyrie? I am wanting a 90 degree and found some chrome at Jake Wilson for $2 each but skeptical because the other ones are between $12- $20. Is anyone familiar with them? But I do need a size. On one site I had to choose between an 8 or 10, another 453" hole!? :-\
http://www.jakewilson.com/p/52/-/343/753/-/19082/Myers-90%C2%B0-Tubeless-Chrome-Valve-Stem?term=valve stems
Those are the good ones that tighten from the outside.  That way if they need a little snugging, you can do it without breaking the bead.
Hay  8)
BIG--T
Quote from: HayHauler on Tue 03, Sep 2013, 15:35:40
Hay  8)
Thanks Jimmy for the quick reply as I'm in the process of ordering some...at $2 a pop is a deal compared to the others!
Do you know the size I need? 8, 10, 453"?
Spirited-6
Hay  8)
I`m sorry but how in the hell can you work from the OUT SIDE to tighten . I wish some one would shop me this. :-(
Spirited-6
Quote from: Spirited-6 on Tue 03, Sep 2013, 16:20:57
Hay  8)
Study the picture, the nut is on the outside.  Hoser
BIG--T
donaldcc
I have the $2 JakeWilsons and they are great.  can't beat that price.
Don
BIG--T
Quote from: donaldcc on Tue 03, Sep 2013, 21:10:39
That's exactly where I ordered mine!  :cooldude:
Hay  8)
The flange is on the inside of the rim and the nuts are on the outside.  These are not the PatchBoy stems I have seen in the past.
Hay  8)
