Front brake lines Valk interstate
Started by robin, Thu 07, Nov 2013, 19:03:12
Previous topic - Next topic
robin
Anybody know the length of them i want to get stainless but just a little longer?
shortleg
  What kind of length you need, or  where to where.
         Shortleg[Dave]
The Anvil
If they're for an I modified production model (no custom bars or anything) then Spiegler or Goodridge should just be able to pull up the info. I had to custom order mine but I have drag-bars.
robin
I want to add risers and not have to relocate the lines so if they are a little longer it could all go back to the stock position
Detn8er
Quote from: robin on Fri 08, Nov 2013, 18:04:21
I have the deuce risers on mine.....I ordered lines 2" longer than stock......They work just fine but I'm sure 1" longer would have worked just as well.
wiggydotcom
Quote from: Detn8er on Fri 08, Nov 2013, 19:11:23
I could be wrong but I think when you order, using the info from Detn8er, you'd just pick the Valkyrie cable and the +2 option to add those two inches.
VRCC #10177
VRCCDS #239
donaldcc
  I have Galfer brake lines front and back and the people there were very helpful talking me into getting shorter ones than I had planned on and they were right.  Give them a call and they can help you out quickly with the right answer.
http://www.galferusa.com/motorcycle-brake-lines/
Don
