Tacticool Mosin Nagant (Gun Humour, Non-Valk)
Started by Serk, Sat 23, Nov 2013, 00:23:20
Previous topic - Next topic
IN NAME OF LENIN, STALIN AND KHRUSHCHEV WHAT IN VLADIVOSTOCK HAPPENED TO THIS GLORIOUS SOVIET ENGINEERING MASTER PIECE? WHAT WAS WRONG WITH MOSIN NAGANT THE WAY IT WAS CONCEIVED BY ILLUSTRIOUS VISIONARY SERGEI MOSIN FOR MAXIMUM KEBAB REMOVING LIKE VASILI ZAITSEV HAS DONE TO GERMAN FACISTS?
THERE IS NO NEED FOR THUMBHOLE TO HOLD GUN IN HAND. YOU GIVE HANDLE IRON GRIP LIKE REAL MAN AND GUN WILL HOLD FINE. STUPID NEKULTURNY AMERICAN UNKEBAB REMOVING CAPITALIST PIGDOG HAVE TO ADD RAIL TO PUT MORE CRAP ON IT. LASER POINTER? FLASHLIGHT? NO NEED. YOU USE 3 METER FLAME FROM MUZZLE TO SEE WHERE BULLET GOES. WHERE IS BAYONET? THERE CAN BE NO EFFICIENT KEBAB REMOVING WITHOUT GLORIOUS BAYONET. AND WHY IS BIPOD THERE? BIPOD MEANS PUTTING GUN DOWN LIKE LAZY SWINE AND PUTTING GUN DOWN MEANS NO STABBING KEBABS WITH BAYONET. AND WHY IS THERE SCOPE THAT IS NOT PU? IS PU NOT GOOD ENOUGH? LINES WITH ARROW NO GOOD, SO YOU HAVE TO ADD SCOPE WITH TINY MARKS TO HELP GUIDE BULLET? NYET. IS 7.62X54R. WHATEVER 7.62X54R HIT WILL BECOME DEAD AS ROMANOVS. OIL CAN TO REDUCE NOISE? WHAT THE VLADIVOSTOCK YOU NEED TO HIDE FROM KEBABS FOR? IS SCARING KEBABS TO DEATH WITH ROAR OF RAGE FROM GUN NOT GOOD ENOUGH FOR YOU?
REMOVE ALL GARBAGE AND UNRUIN IT.
The Anvil
An oil filter? I wonder how well that works???
9Ball
they sell the adapters on ebay for 10/22 and Mark II/III and others....probably work ok for a .22
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
 WHAT THE VLADIVOSTOCK  indeed.
Instead of an old beater tacticooled, how about a modern rifle oldschooled?
The Anvil
CajunRider
Sent from my Apple IIe
musclehead
Quote from: The Anvil on Sat 23, Nov 2013, 06:32:36
does it like synthetic or dino?  :2funny:
Quote from: The Anvil on Sat 23, Nov 2013, 10:45:09
Quote from: Serk on Sat 23, Nov 2013, 10:26:41
Oil Filter Suppressor
I AM BUYING ONE OF THOSE...  :o
There's evidently conflicting rulings from the ATF as to if you can replace the oil filter... So beware...
Quote from: Jess from VA on Sat 23, Nov 2013, 07:12:57
That seems all well and good, but, how many miles before replacement ?   ;)
The Anvil
I would never do anything to run afoul of the BATF. Federal PMITA prison kinda doesn't sound like a good time to me.
However, I think the BATF would have a hard time convicting you for replacing the filter since it is not a serialized part or even part of the serialized, NFA registered piece. For instance, you can swap out uppers on an NFA registered lower and you can replace common wear parts on an NFA registered lower. The element in this case is essentially a wear part. Another example might be that some suppressors are designed to work wet. Is it a violation to add more water or oil?
I had an interesting conversation with my gunsmith about dealing with the BATF on these matters. Often the people writing those responses are not well versed in the details of the law and how it applies but you can bet your ass that your FFL dealer is. I'm going to ask him what he thinks about this.
The Anvil
Check this out:
http://www.thetruthaboutguns.com/2013/05/foghorn/the-truth-about-sig-sauers-ar-15-pistol-arm-brace/
That's a device that I saw and said "NFW is that legal" because it's an awful lot like a CQB stock. But the article clears up some misconceptions.
That big old filter works fairly well, but it plays hell on the sights.
The Anvil
Quote from: Jess from VA on Sat 23, Nov 2013, 11:56:46
I know. That's why I'm thinking that I just might stick with my original plan and but a Tac-Sol suppressor that fits flush with my Tac-Sol uppers.
Quote from: Serk on Sat 23, Nov 2013, 00:23:20
Scope, shmoope !  Simo Hayha didn't need no stinking scope !
hueco
Thanks. That sure beats a plastic pop bottle stuffed full of cotton balls and ducked taped to the barrel. :crazy2:
