Lesson learned the hard way
Started by Oss, Sun 09, Mar 2014, 09:22:12
Previous topic - Next topic
If you have an aux fuse panel and your battery
charger tail is hooked thru it you may NOT be able to charge the battery
I am not sure if mine is or isnt but I took the battery out this morning as the bike was still dead
figuring it should charge faster in the heat of the house than the 30 degree garage
In the light of my man cave computer room I saw the back of the charger says blinking red light means not hooked up correctly,
Well since I know I hooked it up right that only leaves the aux panel so now its already more than 80% charged  (blinking green light)and I MAY be able to ride over to Stan's today in the 34 degree day  brrrrrr
thank goodness for heated gear
So folks if y'all have a charger hook it up directly to the battery and not thru the aux panel
or take off the seat and use the alligator clips
