News:
Main Menu
Norbert of South Africa
Started by Hook#3287, Tue 11, Mar 2014, 18:11:13
Previous topic - Next topic
If you like a story of perseverance, try and get through the 350+ posts of this thread.
http://www.ngwclub.com/forum/viewtopic.php?f=16&t=48860
Norbert from South Africa jumps through some hoops re-habing his naked wing, but the best is the picture/poster he made when his engine was apart.  :cooldude: :cooldude: :cooldude:
alph
wow!!
haven't gotten through ALL of the post, but from the few pages I saw it was really neat!
looking at that old Goldwing you can see it looks better as a sport bike.
Ride Safe, Ride Often!!  :cooldude:
Otus
Wow, that engine was beautiful when he got it back together. Snagged me a pic of the engine laid out on the floor.
Damn that was a story of perseverance ! Very interesting. Good luck on yours hook :cooldude:
Quote from: meathead on Tue 11, Mar 2014, 21:07:06
Meathead, thanks for the luck, I'll need it.  Hopefully not as much as Norbert did. ;D
I also have been watching Norbert's string, I used his videos to split the case on the GL1200 I'm working on. Mine had a piston with a hole in it...swallowed a valve. So, instead of buying a replacement engine again I decided to pick up a set of used rods/piston off Ebay....sort of a gamble. I'm hoping my gamble pays off, the new/used pistons were in great shape, the rings and bearings were well within spec so I reused them. I doubt I would have tried it until I took a look at his videos, and I still had some major headaches. But, I have it back together and waiting on gaskets to complete the reassembly, then I'll install it in the bike.
Quote from: Hook#3287 on Wed 12, Mar 2014, 15:46:26
yeah no doubt! I know I would have given up with disgust long ago. And from the sounds of it he never worked on engines before this.
