News:
Main Menu
Back To Stealer!
Started by Kelly, Wed 19, Mar 2014, 07:40:08
Previous topic - Next topic
Kelly
So I had the problem of 1cylinder not firing during idle only. The dealer had it twice. I had to take it back the 3rd time since a different cylinder was acting up.
After a week Dealer says Bad spark plugs and replaced all six. Nocharge to me.
I have about 150 miles no problems .We Shall See.
Does any one have a way to affix an Auxillary input jack on or near the handlebars?
It's got to be the goin not the gettin there that's good!
MP
My IS came with an extension.  Plugged in under RH cover, then routed up to the handlebars.
MP
"Ridin' with Cycho"
PAVALKER
Get an audio extension cable and run it from under the right side cover along the frame under the tank up to the bars.  Wrap any excess up and tuck it away.
John
Kelly
Yea that works for me. I bought a Saddleman to hold ipod also.
Questions for the Veterans.
I am replacing windshield and need new fairing screws, cannot find them in motosports oem pages?
I expect to have the embedded inserts come loose. I do have a couple damaged screw heads already and will gave to drill them out/extractor. Iwould like to put oem screws back in.
I found 1 rear speaker dead, so ordered 2 pyle 4" 4 ohm speakers that should drop in.
My estimation is the 4 ohm will not hurt the radio even though the original rears were 3 ohm...any thoughts?
LED rear  14" brake light , found it NIB 9 $ on EBay. In automotive.same item made for Valk,69$ ,I did have remove sticky pads and drill 2  1/4 holes but it is same item.
Stealer put 6 new plugs in bike and re-sync carbs, SHE RUNS AS SHE DOES IN MY DAYDREMS,!
PAVALKER
Not sure if these are same.... But I saved the link for future reference.   http://www.ebay.com/itm/121303308445?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
If th nuts come out... Just epoxy em back in and antiseize the screw threads.
John
Quote from: Kelly on Sat 29, Mar 2014, 08:16:49
There is a thread here listing the part #'s of the OEM screws and grommets somewhere. A couple months ago some one else was asking about them and it was suggested to epoxy those in so when removed again the grommet would stay.
Big Al of Tennessee
Quote from: Kelly on Wed 19, Mar 2014, 07:40:08
Smooth Rider had the same problem on the same plug. Your drain in the head casting is plugged.
Moisture is gathering in that hole where your plug wire is, in the well. Literally, it has a drain hole
that is not draining. Killing your spark at idle. We did not even know those had drain holes. As we thought the grommet kept the moisture out.
Worth a look.
Gotta link for the brake light?
Kelly
