Speakers for Woody's Fairing
Started by doniholcomb, Thu 17, Apr 2014, 09:41:57
Previous topic - Next topic
doniholcomb
I have pulled the trigger and ordered a woody's fairing from glenn, now I need a little help in choosing the speakers. I know that I will want to upgrade in the future and don't want to have to open up the speaker holes in the future. What I need to know is what kind of speakers should I get, the out side diameter can be no larger that 6 inches. Glenn said it is ok for me to send him the speakers I want to use and he will install them for me. I was looking at the
Found these from jvc CS-V528
General Features:
5-1/4" DRVN Series 2-Way Car Speakers
Power Handling:
Peak: 440 watts per pair / 220 watts each
RMS: 54 watts per pair / 27 watts each
Carbon Mica cone material
Durable hybrid material speaker surround
1" Polyetherimide (PEI) tweeter
High temperature voice coil
Ferrite magnet motor structure
4 ohms impedance
Top-mount depth: 1-3/4"
The manual from the jvc web site says the diameter is                5 7/16 inches.
If any of yall have up graded your woody, what speakers did you use?
jimmytee
I installed Kicker 5.25" speakers in mine. Powered by a Kenwood amp. I'm verypleased with the results. I used the grills from ones that Glenn provided because the grills that came with Kickers were too big. This meant cutting the grills from the original speakers with a dremel. Easy peasy. I mounted the speakers from the inside with the grills on the outside. No modification of the speaker holes needed. BF used some Sony speakers with a Rockford amp he liked. He did have to enlarge the speaker holes some with a drum sander on a drill.
http://www.valkyrieforum.com/bbs/index.php/topic,54888.0.html
jimmytee
