Windshield that will protect my passenger?
Started by ValkSmile, Thu 24, Apr 2014, 08:46:14
Previous topic - Next topic
ValkSmile
I'm looking for a windshield for my IS that I can look over and will get the wind up over my passenger  a little better. Has anyone tried one of these windshields from Gustafsson Plastics? He said he can make me a stock height of 15.5 with a "EuroFlip" at the top. Wonder if this with eliminate most of the wind for the passenger?
http://www.bikescreen.com/proddetail.asp?prod=HondaGL1500ValkyrieSP970312Tall2712WideEuroFlipWindscreen
Having a shield that protect the passenger (virtually always on an elevated seat, compared to the rider), but which can still be seen over by the rider is an age old issue.  I have no exp with that shield, but have read that the laminar lips and recurved shield tops raise airfow higher than traditional shields. How much, I do not know.  There is even a rubber edging that can be purchased, trimmed to length and slipped onto a std shield top that pushes airflow up. It is ugly, but works, to some degree.
My 2 cents is to get the proper shield height for you (driver), then do what you have to for the passenger.  And that is generally having them wear a full length helmet visor and good eyewear that keeps the effects of excess airflow and bugs to a minimum.
Getting a shorter woman is another solution, but that presents a whole different can of worms.  ;)
I have the "flip", or re-curve at the top of a couple of my shields that I use on my Woody's fairing.
They DO help....and at speed, it's like adding an extra 1 1/2" to 2" to your shield.  However, the effect depends on your speed.  Slow speeds....not so much.  The effect is best at highway speeds.
Do you have any other wind defectors on your Interstate?  A set of Bakers along with some fork mounted lowers/deflectors will go a long way for wind managment.
If you can find them, I think Honda once offered a set of wing deflectors that mounted to the sides of your Interstate shield to help with wind.
ValkSmile
BF....She is mainly complaining about the air that is hitting her in the face at highway speeds, 55+, so maybe the flip shield will work for me if you say it helps at the higher speeds. I do have a set of Honda fork deflectors, but I run without them in the summer to get more air on my body.
konigralph
I think that most of the time once you hit those higher highway speeds, your passenger is going to get the wind hitting them regardless. it's a bit harder to have a windhsield that'll deflect all the way to the passenger at 75mph+ and not ruin your gas  mileage completely.  (aerodynamics )
NEHI
   I have a Laminar lip on my I/S. It makes a noticeable differance for me, but my SO says it makes a huge differance for her. Placement on the windscreen is important. I have mine so when I look over the top of the windscreen I look just over the top of the Laminar lip. I have a used windscreen that I drilled many holes in so I could get the right placement 1/4 inch up or down made a noticeable differance.
john
                   :coolsmiley:
          no wind ?           on a motorcycle  ...          ???    :-\          :)
vrcc # 19002
signart
Quote from: john on Thu 24, Apr 2014, 16:22:55
                   :coolsmiley:
That's what I was thinking. It's a motorcycle!
Me too, I  was thinking get in the car and roll the windows up.
Thunderbolt
You will probably have to look through it but the Tall Tulsa windshield is the only one I found that protects the passenger.  Of course that depends on your passengar's height too.
Momz
Tulsa Windshields has/had a windshield an extra tall model that almost leaned back and almost covered the drivers head, thus keeping the passenger out of the wind and virtually kept both rider/passenger dry in the rain.
Two of my Valks have no windshield and my I/S has a "shorty". They are motorcycles, not cars. JMHO
ALWAYS QUESTION AUTHORITY!
Mr.BubblesVRCCDS0008
I have a showchrome windshield on my interstate it is 2in taller than stock and a total of 8in wider. I'm 6'2 and wife is 5'10. I can still look over the top in bad weather and she says the wind doesn't hit her at all. I've ran this shield over 100k miles now.
ValkSmile
I know, I know, I love the wind, but at higher speeds its just a little too much for the lady. It looks like if the Laminar Lip works for NEHI, maybe this shield by Gustafsson would help my cause, gotta keep her happy. I have had a tall Tulsa shield in the past and I just cant stand to look throught it, too dangerous, ended up cutting it down. I ride in all sorts of weather and fog so the tall Tulsa just won't work for me.
DenverDave
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
Quote from: ValkSmile on Thu 24, Apr 2014, 08:46:14
I've met the guy and had him make a windshield for my old Goldwing.
He recently made a windshield for a friends VTX 1800.
I had him make me some new wings for the fairing on my Interstate.
He does GREAT work and he's a REALLY nice guy.
He did the euro flip for my friends VTX and it works great.
Eventually, I'll get him to make me a custom windshield for my Vulcan.
