News:
Main Menu
Tires??
Started by flcjr, Thu 22, May 2014, 23:59:31
Previous topic - Next topic
flcjr
 I need a new front tire. Rear is an e3 less than 2k on it. Should I go with e3 on the front or is a different one ok? I tend to lean towards another e3. I haven't ever had problems with them.
Where to buy. Seems prices have gone up lately
Personally I have never had an E3 that I liked but if you aren't having a problem with them why switch? It will not hurt anything to run a different front and rear though.
Consider a Metzler 880 for the front and I have good luck and currently have a Shinko S E 890 on the front of my I/S. BUT be forewarned-a Metz IS spendy. RIDE SAFE.
Jack
If you like your E3, you can keep your E3.
Big Al of Tennessee
What tire do you have on the front now?
big poppa pump
Michelin Commander II 140/75 on the front. 10k+ miles and still counting.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Big Al of Tennessee
Quote from: big poppa pump on Fri 23, May 2014, 12:29:19
I hear that the Michelin Commander II is a very good tire.
Cups very little and long wearing. Can you attest to that?
I may buy one next time.
big poppa pump
Been keeping at 40 PSI rigorously since the time I got the tire installed. No cupping at all and I still have about 3k-4k miles left on the treads. Beautiful handling on highways, tar snakes, grooved roads and absolutely wonderful on twisties with my rear CT.
VRCC#35870
VRCCDS#0266
flcjr
Quote from: Big Al of Tennessee on Fri 23, May 2014, 12:03:36
I have a balding E3. Has been fine just worn out starting to make some noise. I usually replace them together but rear was replaced do to a puncture wound on the road the front was fine then and didn't see the need of over paying on vacation.
Making a bit of road noise Is no reason to replace unless you are having handling problems or the tire has tread down to the wear marks. The set I have on now makes some road noise especially in corners at hiway speed but still have over half tread left.
