This was my first time........
Started by Stanley Steamer, Sun 28, Sep 2014, 21:46:04
Previous topic - Next topic
Stanley Steamer
doing my new tire solo.....I knew it'd be a little more aggravating, but I had to get it done for the Fall Color Ride......100, 931 Mile Valkyrie Rear End Maintenance and new Tire......
I took a 150 mile ride yesterday to get the last few miles out of this tire.....I think I did ok....6,452 miles on this tire..... :cooldude:
Here's the drive shaft end that goes into the pinion cup.......just a little wear on that one side of the teeth....not bad for 100,931 miles....?? :-\
I plan on replacing the driveshaft and pinion cup the next tire change
the other end looked ok.....I cleaned it up a little better and re-greased it...
the teeth on here look pretty good........I replaced all the O-rings and MDP'd everything before I put it all back together.....
Getting the wheel back on while trying to line up the axle and the brake rotor was a PIA......but I got it all back together and didn't have any parts left over....... :cooldude: :D ;D
Stanley "Steamer"
"Ride Hard or Stay Home"
Stanley Steamer
Oh yeah.....I also changed the wheel dampners......hadn't been done since around 70,000ish miles........at Smokin Joe's house.....the weekend Old School had his fatal wreck...... :( :(.......
I've noticed a slight "sloppiness" as of late, and they were pretty loose with lots of shredded rubber in the holes.......new ones went in very nicely....
https://www.youtube.com/watch?v=kCAXlx-sJNg
Stanley "Steamer"
Ghost
Nice job Stanley, did Cletis Help.
I just wanna Ride............:)  And hang out with all the cool Kids riding Motorcycles.
Stanley Steamer
Quote from: Ghost on Sun 28, Sep 2014, 22:10:02
Nope.....he was off catting around
Stanley "Steamer"
KY,Dave (AKA Misunderstood)
Good job. Gotta tear mine down now too for new tire and all that goes with it (lubing splines etc.) . Did my dampners last change so can skip that hopefully.  :cooldude:
Tundra
Stanley, have you replaced your splines? They show no wear at 100k? Look like new.
Stanley Steamer
#6
Quote from: Tundra on Mon 29, Sep 2014, 04:38:47
I've had the bike since 29,000.....those are the original everything
Stanley "Steamer"
Looking good :cooldude: (never thought I'd say that to a steamer post) :2funny:
Quote from: Stanley Steamer on Mon 29, Sep 2014, 05:05:13
Good job Stan.....as long as you got the axle then immediately the 4 bolts thing right, you really cant screw it up.  Im sure you used some good grease, those two things are critical, the rest is just so many nuts and bolts
Yeah, that's tough sometimes... people have been suggesting to get it all back together,
axle and everything, without the caliper... then slip the axle back out an inch and
slip in the caliper... I think that's it... I'm going to try it next time...
You left out that you changed the tire yourself too...  :cooldude:
Stanley Steamer
Quote from: Chrisj CMA on Mon 29, Sep 2014, 05:36:10
Yep....the 4 bolts on the pumpkin were the last ones I tightened
Stanley "Steamer"
I was 'hesitant' to open this post. We KNOW you my friend!  :2funny: Splines look pristine. Mark T gave me a suggestion I'm passing on to you for the next service of the splines. A 1" ratchet strap thru the wheel opening and over the fender on the reinstall acts as your 3d hand. First couple of spline services it fell back together-THEN I ran up on the spline service from hell!!  :evil: I am also approaching the 100000 mile club on my Phatt Ghuel. Again-insides of that spline P-cup area lookin cursed good. Sooooo afraid too ask BUT did Cousin Cletus get laid??  :roll: RIDE SAFE.
GiG
Quote...to get it all back together,
Yep, that's how I do it...  :cooldude:
Everything is - Nothing is .
(send it to OSS)
I'm putting in a call to the League Office!   🎳
Punisher
Quote from: Motor City GiG on Mon 29, Sep 2014, 07:41:39
It ensures that everything is lined up properly before you push the wheel into the pumpkin so that you don't pinch an o-ring, especially the big one behind the flange teeth.    Without doing it that way your first sign of a possible broken o-ring is a lot of grease slung out on the wheel, especially after the first ride and wipe off, if it keeps getting slung out.
Last not exactly right.  Next after axle is the time to do it to insure best alignment of the drive!  :cooldude:
Pepmyster
Now this is getting interesting........
Stanley Steamer
Quote from: Chrisj CMA on Mon 29, Sep 2014, 17:32:50
What i meant was it was the very next thing i tightened after the axle....while it was still on the lift....hope i didn't bugger that O-ring up that punisher was talking about
Stanley "Steamer"
Punisher
Quote from: Stanley Steamer on Mon 29, Sep 2014, 19:15:59
You'll know soon enough and if unlucky then get to pull things down and do it again.   It's a lesson that doesn't take more than a time or two to learn.   8)
Stanley Steamer
Quote from: Punisher on Mon 29, Sep 2014, 19:31:09
With the way my luck's been, the whole damn wheel will probably fall off..... >:(
Stanley "Steamer"
wiggydotcom
Forgot to ask you on Facebook, how bad was the actually tire change....off with the old and on with the new? Do you have the Harbor Freight changer?
VRCC #10177
VRCCDS #239
Quote from: wiggydotcom on Mon 29, Sep 2014, 20:07:39
I taught him everything I know...  :roll:
The O-ring will be OK  :cooldude:
Stanley Steamer
I was going to ask Santa for one this year, but i haven't gotten anything else I've wanted....I built a home made bead breaker, but otherwise use the 2-3 harbor freight tire irons and power it on....wasn't too bad ....used dawn dishwashing soap
Stanley "Steamer"
