November 24, 2025, 06:33:17 PM *
Author Topic: Nice safety feature  (Read 852 times)
Beer van Huet
Netherlands
« on: January 24, 2015, 08:36:03 AM »
I disassembled my windscreen and noticed something I had not noticed before.
The Valkyrie windscreen frame mounting will topple in case of a frontal accident, hinging at the bottom. I always thought the top cut out was to adjust the screen, which is also true.
Better not tighten the top nut too hard.
Nice job, Honda.
« Last Edit: January 24, 2015, 08:38:08 AM by Beer » Logged
« Reply #1 on: January 24, 2015, 12:11:28 PM »
Nice job, Honda.
What Beer said is very important.  I had a get off (low side) and when the engine guard hit,  the bike stopped!  I didn't stop as fast and therefore I went through the windshield.  I must have had the upper bolts too tight because it failed to swivel.  I even knew about that safety feature and didn't think I had them buggars tight enough to hold against a body hitting the inside of the shield, but it held, and I broke my hand busting through, it could have been worse though if I didn't have a full face helmet on (helmet was trashed from the windshield)
A couple things to think about.....upper bolt and full face if you run a large shield
Psychotic Bovine
New Haven, Indianner
« Reply #2 on: January 24, 2015, 01:54:31 PM »
I know my 1991 Yamaha FJ1200 had nylon screws holding the clear part of the windscreen on.  The idea was that they would shear off in the event of a head on collision.  I only found out about it after I broke one when removing the windshield one day.
"I aim to misbehave."
saddlesore
« Reply #3 on: January 24, 2015, 04:23:04 PM »
WOW! I never knew that. I have a Memphis Shades wind shield but it's cut the same way. I have an adjustment to make before riding in spring.
Thanks cooldude
DARE TO BE DIFFERENT
« Reply #4 on: January 24, 2015, 05:59:27 PM »
When my top bolts aren't tight, I've notice I can move the windshield. It's
not like I see it moving when I'm riding, I just notice it moving when I'm
cleaning the bike or something... maybe I better loosen them back up...
DK
Little Rock
« Reply #5 on: January 24, 2015, 06:05:59 PM »
Be sure the OE "center spacer" washer is present on the top attachment points.
I misplaced one a while back & replaced it with a flat SS washer on both sides so as to be a match.
It never occurred to me that this was a safety feature, but just an adjustment point and to facilitate eaisier removal.
I'm ordering the proper washers next week.
I suppose there is a critical torque setting?
Windrider
2000 Valkyrie Tourer
SE NE
« Reply #6 on: January 25, 2015, 02:30:42 PM »
I'd noticed the cut out, but had not thought of the safety aspect.  I'll be checking the bolt tightness on mine.  Boy, there's a lot of good info on these boards!   cooldude
« Reply #7 on: January 25, 2015, 04:38:14 PM »
Speaking as a man with too much experience on crashing bikes,  Shocked I would just as soon hit the windshield as the ground or anything else.  I really don't believe it is a safety feature as much as making a one person removal or install the of the windshield easier.  Hoser
Challenger
« Reply #8 on: January 25, 2015, 04:49:43 PM »
 +1
