Meh, a mere 334HP @ 12,800rpm
ENGINE
Configuration: 90 degree V8
Capacity: 1996cc
Bore/stroke: 77 x 54mm
Compression ratio: 13:1
Cylinder Head: DOHC, five valves per cylinder
Cooling: Liquid
Fuelling: 8 x 45mm Mikuni Drive-By-Wire throttle bodies
Engine Management: Motec M130 ECU and software.
Power: 334HP@ 12,800rpm (At the countershaft sprocket)
Torque: 214Nm @ 9,500rpm (At the countershaft sprocket)
Exhaust: 2 x 4-2-1 titanium
TRANSMISSION
Type: Six speed sequential gearbox
Clutch: Wet, multi plate
Final Drive: Chain (17/45)
CHASSIS
Rake: 25.5 degrees
Trail: 107mm
Material: Front - Chrome-moly tube trellis
Rear - CNC machined Aluminium
SUSPENSION
Front: Ohlins FGRT301 48mm USD forks... fully adjustable
Rear: Ohlins TTX Mk2 shock, with custom link
WHEELS/TYRES
Front: 17.0 x 3.50 Marchesini 10 spoke, forged aluminium
120/70ZR-17 Michelin Pilot Power 3
Rear: 17.0 x 6.00 Marchesini 10 spoke, forged aluminium
190/50ZR-17 Michelin Pilot Power 3
BRAKES
Front: Brembo GP4 Nickel plated calipers on 320mm discs
Rear: Brembo P4-34 Nickel plated caliper on 220mm disc
DIMENSIONS
Weight: 242kgs wet with fuel, water and lubricants
Weight bias 51/49 front to rear static
Seat height: 840mm
Wheelbase: 1540mm
Fuel capacity: 16.5litres
PERFORMANCE
Top speed: How brave are you?
Specifications subject to change without notice.
