November 23, 2025, 05:37:03 PM *
Author Topic: Throttle assists  (Read 1569 times)
WoodyFL
Ocoee, Fl
« on: May 16, 2015, 04:03:51 PM »
Posted this first in the Florida board but thought I'd post it here also.
Thinking about taking the Valk on a trip up to Chicago end of June/early July.
Was wondering if any of you have experience with either a throttle lock or throttle assist?
Any suggestions would be welcome.
Thanks!
Woody
2000 Blue/Silver I/S
Ocoee, FL
Misfit
Colorado Springs Colorado
« Reply #1 on: May 16, 2015, 04:16:49 PM »
Madco Rider is the one I use. Quality piece made by one of our own.  cooldude
« Reply #2 on: May 16, 2015, 04:22:07 PM »
I have this on both bikes.  (you can spend more, or less)
Not having an automatic brake shut off is simply not a problem, you adjust the cam lock so it just holds the throttle against the return spring, you do not have to release the lever to release the lock, you just twist the throttle back to idle (against the lock).
http://www.madcorider.com/cam-lock_honda_cruisers.html
I looks like part of the bike.  I have the Kury ISO grips with throttle boss and the cam lock together and they work well together.
Edit: You beat me to it Misfit.  I did not know the seller was one of us.  When dealing with him, he was an extremely nice gentleman, and mailed it to me the same day I mailed him my check.
« Last Edit: May 16, 2015, 04:24:41 PM by Jess from VA » Logged
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: May 16, 2015, 04:31:39 PM »
I've been using these for 40 years: http://www.aerostich.com/crampbuster.html
And these for 5: http://www.aerostich.com/go-cruisetm-throttle-control-1.html
« Reply #4 on: May 16, 2015, 05:05:51 PM »
Been using that paddle since shortly after I got her. NOT really recommended BUT I have gone on the slab with one finger on the paddle and the left hand NOT on the left grip at all. That paddle and 1 inch over stock height risers on my I/S have made a world of difference for these old arthritic bones. RIDE SAFE.
PAVALKER
Pittsburgh, Pa
« Reply #5 on: May 16, 2015, 05:53:34 PM »
Vista Cruise throttle lock on the bikes for the last 15 years I think.  Works well, not that pricey either.
http://www.motorcyclecloseouts.com/extras/cruiser+accessories/sound+off+recreational_vista+cruise+control+-+universal?utm_source=gps&utm_medium=csn&utm_term=Vista+Cruise+Control+-+Universal&utm_campaign=extras-cruiser+accessories&gclid=Cj0KEQjw1duqBRDPlLKsuJCUiuABEiQAxgHwJyoPqRehPIL5f8SReCgXqc1EK87GTht2kvvF0rmeK3MaAvCn8P8HAQ
« Last Edit: May 16, 2015, 05:55:51 PM by PAVALKER » Logged
John
Mr Whiskey
« Reply #6 on: May 16, 2015, 06:01:27 PM »
Been using that Crampbuster for so long now I have trouble tach'n r's on the downshift without it  cooldude
Peace, Whiskey.
« Reply #7 on: May 16, 2015, 06:09:13 PM »
I went with the Australian, I think it was, electronic cruise control.
Have over 300,000 care free miles on it and not one failure.
Expensive, but well worth the $$$$ in my book.
I can take off down the highway, set the cruise and enjoy the ride.
Tap the brake lightly and the Cruise sets itself off.
« Reply #8 on: May 16, 2015, 06:25:30 PM »
I love my BrakeAway.
https://www.brakeawayproducts.com/
It looks factory and works smooth as butter.  Easy to install and set up.  No glitches, no problems, no issues with losing throttle settings....it just works flawlessly and looks like it's supposed to be there from the factory.
Tailgate Tommy
Fort Collins, Colorado
« Reply #9 on: May 16, 2015, 06:32:15 PM »
+1 BrakeAway works great for me.
Misfit
« Reply #10 on: May 16, 2015, 07:33:58 PM »
Jess, next time you have your throttle grip off take your throttle lock off and turn it over and reinstall. It will look even better upside down. When in this position you lift the lever to set the lock and push it down to disengage. Works well and looks great up side down. If I was smart enough to post a pic I would.  cooldude
Mr Whiskey
« Reply #11 on: May 16, 2015, 07:40:41 PM »
Sweeeeet! I'd never even heard of that before, thanks!
Peace, Whiskey.
« Reply #12 on: May 16, 2015, 08:27:47 PM »
Had Vista Cruise for years, upgraded to BrakeAway some years ago, no comparison.  Put the same on the wife's Magna.  Works great, never needs adjustment, looks good.  Yeah it's pricey, but like Oskar Schindler said, "Nice things cost money".
« Reply #13 on: May 16, 2015, 08:30:03 PM »
I thought about that before, but with the keeper (holding it in place) between the throttle cables, I did not see how it could be done.  (I have seen the older Vista Cruise turned upside down, which hides that crossbar.*)
That is not my bike in the pic I posted (I don't post any pics but those on the web I find), and with the IS throttle cables coming out much lower, it looks better than in that pic.  I don't use it all that often, except on trips and when I need to briefly use my right hand away from the throttle. I use the boss more than the lock to rest my hand.
*  http://www.rattlebars.com/mtz/invisible.html
« Last Edit: May 16, 2015, 08:32:14 PM by Jess from VA » Logged
specialdose
Jonesboro, Ga
« Reply #14 on: May 16, 2015, 10:09:41 PM »
      +2 BrakeAway. Looks like it came from Mother Honda. Works as well as it looks. Folks ask when hey see it if its factory.
« Reply #15 on: May 17, 2015, 03:31:23 AM »
If you dont have electronic cruise control the next best thing is the breakaway
Couldnt imagine two weeks on the road without it
Wish I also had one on the bmw
BobB
« Reply #16 on: May 17, 2015, 07:27:20 AM »
I have been using the MADCO Throttle Lock for seven years, still looks like new.  MADCO also supplied a ring for the clutch side so both grips match up.  I also use a Kury throttle assist...
WoodyFL
Ocoee, Fl
« Reply #17 on: May 17, 2015, 07:53:50 AM »
Thanks for the suggestions!
I agree the  Breakaway looks like it's part of the bike, although a bit pricey.
The Go-Cruise looks simple and inexpensive but sticks out like a sore thumb.
Have lots of things to compare in the weeks ahead.
Thanks again guys for all the input!
Woody
Ocoee, FL
« Reply #18 on: May 17, 2015, 05:13:07 PM »
Woody
Once you see how well it's made and how well it functions, you won't think the BrakeAway is too expensive at all.  The BrakeAway functions like a fine Swiss watch.   cooldude
https://youtube.com/devicesupportpowered by Aeva
« Last Edit: May 17, 2015, 05:18:27 PM by BF » Logged
PAVALKER
Pittsburgh, Pa
« Reply #19 on: May 17, 2015, 05:43:24 PM »
Woody
Breakaway does not work with heated grips, whereas Vista Cuise does.  You can flip the Vista Cruise upside down to hide it a bit, but with my black heated grips....it's not that noticeable.
John
