There is a small plastic device that you might want for the Miata. Called "Light in sight". Fresnel lens that is about the size of a credit card that allows you to see the traffic light when the top is up. easily installed or removed. Also suggest the crazy Italian Red air horns. And finally there is a company that makes a simple air scoop that snaps onto the windshield when the top is down. Brings in the fresh air nicely, the transmission tunnels can get pretty warm.
Great ride, loved mine.
Gil
Thanks. Interesting about the Fresnel gizmo. Used to see those on cars with a windshield hood back in the Forties. For some reason, no problem with that. On the last Miata (a '99) I removed the sun visors for a better view, no need on this one. And yes, I had one of those scoops on the '99, almost forgot, it worked fine. As far as horns, if I replace them it will be with the big red Hellas. Doubt it though, too hard to get at them.
