November 23, 2025, 04:38:05 PM *
Author Topic: Anyone close to Jackson, CA ? would like to compare bikes  (Read 433 times)
Pal
Jackson ,California
« on: June 23, 2015, 07:02:29 PM »
Hi.
I am Pal. Just moved to California, and got a 1998 Valk. It has a glasspack exhaust, and progressive springs.
My 2 main issue is the exhaust noise, and the front end feels strange, and noisy if i go trough bumps.
The previous owner said that the oil in the forks was recently changed in a garage.
If somebody nearby Jackson, CA , would be really cool to meet up, and compare it with another valk.
« Reply #1 on: June 23, 2015, 07:42:46 PM »
Check pressure in tires. First, what tires are on the bike? Run 40F and 40-45 in the rear. Are they worn down and cupped? The clunk in the front is normal to some extent. I have Progressive springs and occasionally have the clunk. A pic of your pipes might tell us what they are.
Pal
Jackson ,California
« Reply #2 on: June 24, 2015, 10:59:08 AM »
Thanks Sandy
I have new Metzeler 880 tires with the good pressure. I now i will have some noise from the free float brake , but thats sound louder + higher. And the bike does not handle bumps well.
The pipes are OK, no backfire or powerloss (i think) , just  irritatingly noisy at some speed.
MAybe i am getting old  Roll Eyes
Here is a pic of the pipes. As you can see the downpipes are thicker than original.
Pal
Jackson ,California
« Reply #3 on: June 24, 2015, 10:59:46 AM »
Leatherman
Jeff & Deb
Oklahoma
« Reply #4 on: June 24, 2015, 02:49:45 PM »
Hi Pal,
I had a poor handling issue on bad roads and it turned out to be the bearings in the triple tree.
Once I had them snugged up, the bike handled like new again. I'm not sure what the proper torque is supposed to be since I had it checked out at the dealership.
A lone individual built the Ark while a group of "Professionals" built the Titanic.  Hmmmm.
Pal
Jackson ,California
« Reply #5 on: June 24, 2015, 04:20:52 PM »
Hi Pal,
Thanks Leatherman.
I will check it out!
If not that i just ask in Tech Board!
