November 23, 2025, 03:33:46 PM *
Author Topic: Interstate Exhaust on a Standard  (Read 662 times)
Harv
One Bad Motor Scooter
Des Moines, Iowa
« on: July 10, 2015, 08:42:59 PM »
Does anyone run IS pipes on their Standard? I have the Mark T pipes with crossover on my standard and they are just to loud for the old lady. I found a nice set of stock IS pipes and was just wondering if anyone is running them on their Standard and any comments anyone might have. Thanks.
Harv Wink
« Reply #1 on: July 10, 2015, 09:19:02 PM »
I/S tips are horizontal and standard/tourer tips are vertical. NOT sure if there is a length difference. I know from first hand experience that Cobra 6 into 6 are noisy. Course I'm getting older!  Lips Sealed Maybe MarkT offers something to quiet down what ya got?? RIDE SAFE.
« Reply #2 on: July 10, 2015, 09:28:29 PM »
Aside from the tip and piggie differences mentioned, all valk pipes will mount to all valks.
I suppose the flat/horizontal IS tips are to give more room under the bags and heat shields, but they should work fine on a standard.
They'll look better with these 18" tips (which don't care if the piggies are horizontal or vertical.
http://store.airflo.com/af40-418hs.html
Flat6Valk
Blacklick, Ohio
« Reply #3 on: July 11, 2015, 06:30:17 AM »
I would consider a trade with you.  my pipes are OEM.
Greg
Flat6Valk
« Reply #4 on: July 11, 2015, 11:19:07 AM »
I believe Mark offers an add on to quiet the pipes.  Hence the name, MildtoWild.
The Interstate pipes will fit fine on any Valkyrie and due to the longer piggies are the quietest stock pipes you can get.
Harv
Des Moines, Iowa
« Reply #5 on: July 12, 2015, 07:58:48 PM »
Thanks for all the replies. Greg, I bought a set of pipes before I read your offer but thanks for the offer. Willow, I went the cheap route when I had Mark modify my exhaust originally and didn't opt for the truck stacks or trombones. Just the glasspacks and crossover. I did buy some little silencers from him later but they don't quiet it down much at all. Eddy thanks for the input, I took your advice.
Harv Wink
