November 23, 2025, 03:28:02 PM *
Author Topic: Mounted a new SS overflow tank on the 1200.  (Read 384 times)
« on: July 14, 2015, 12:49:46 PM »
Doesn't look too bad....I guess. I wanted to make certain it followed the lines of the chrome radiator baffle next to it, which also follows the down tube angle. By adapting a Valk tank to the frame, I could no longer use the OEM plastic thing....which was ugly and had a hole in it anyway. So, in an effort to keep it simple and inexpensive, I ordered a 2"x10" SS unit off Ebay, $28 with shipping. Then mounted it using stuff from my stash of SS paraphernalia. I used some clear plastic tubing so I can tell how much coolant is in it without having to remove the cap. By using a P clamp, I was able to attach the bottom to the engine guard, the top piece is just some SS strap I had laying around. It holds about 18 oz which is slightly more than the OEM unit....and looks a lot nicer. It's solid which is what I was after.
Rear view showing the Valk tank, handlebars, and Valk m/c and controls. Those ugly gauges will be tossed soon as I get to that part of the rebuild. Next project I guess will now be the forks.
« Reply #1 on: July 14, 2015, 12:54:57 PM »
Seems like you're having fun with that thing.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #2 on: July 14, 2015, 02:44:23 PM »
or...you could stash your ceegars in it.
Looks good John cooldude
« Reply #3 on: July 14, 2015, 03:06:40 PM »
Doug, they'd be too hard to light, they'd be wet. Besides, you know I don't smoke.  Wink
Charlie McCready
Gray, Tennessee
« Reply #4 on: July 14, 2015, 04:08:20 PM »
Looks good John, I like it !!!
