November 22, 2025, 08:06:17 PM *
Author Topic: Can of worms = open...  (Read 2473 times)
Daniel Meyer
The State of confusion.
« on: July 27, 2015, 12:28:25 PM »
Working my way around the front. I expect this will take the rest of the year...
http://theoldvictorian.com/2015/07/27/can-of-worms-open
Step one of the front railing project…
1) Rebuild columns.
Step one of the column project…
1) Rebuild the porch.
Step one of the porch project…
1) Rebuild porch header.
CUAgain,
Daniel Meyer
« Reply #1 on: July 27, 2015, 12:40:32 PM »
Man, I'm getting tired just thinking about all that work.
« Reply #2 on: July 27, 2015, 12:45:16 PM »
I'm glad there are folks out there like yourself that have the drive, gumption and resources to restore and maintain these dignified old ladies... Smiley
« Reply #3 on: July 27, 2015, 12:55:12 PM »
I think the can of worms was already opened up in the satanic thread.
Daniel Meyer
« Reply #4 on: July 27, 2015, 01:00:07 PM »
You very politely didn't include "insanity", "stupidity", or "depravity". Smiley
CUAgain,
Daniel Meyer
« Reply #5 on: July 27, 2015, 01:04:38 PM »
That woulda just been redundant...  angel
« Reply #6 on: July 27, 2015, 03:11:46 PM »
You have really done a beautiful job on it so far, I have been admiring your handy work.   cooldude
To me it seems your moving along quite quickly also.
Jersey mike
Brick,NJ
« Reply #7 on: July 27, 2015, 03:34:47 PM »
I hate those cans of worms projects, but what you're doin' is a big 'ole bucket of worms, but doable.
be patient, walk away when pissed, get out for some time on the bike when possible, and resume another day. before you know it, it will be done before long and it will look amazing and the best part is you'll know it's done right.
before you seal up the header, leave a little time capsule up there, sealed up for the next person to find.
I always leave little things tucked away in walls and such when I do stuff like that.
best of luck,
mike
« Reply #8 on: July 27, 2015, 08:55:21 PM »
I do this too, but it's usually parts of my fingertips and skin off my forehead.   crazy2
« Reply #9 on: July 27, 2015, 08:57:36 PM »
2funny ooh that's going to be fun for someone in 20 years.
Hooter
S.W. Michigan
« Reply #10 on: July 28, 2015, 04:37:07 AM »
Pandorah's Box!   Shocked  You need a bigger saws all!
WNGD
Burlington, Ontario Canada
« Reply #11 on: July 30, 2015, 07:38:42 AM »
Beautiful home and well worth the effort  cooldude
We live in a 100+ year old home and are planning a major 2nd floor addition right now. Tyign in new building to historic structure is a trick in itself. And modernizing without losing character....
Tailgate Tommy
Fort Collins, Colorado
« Reply #12 on: July 30, 2015, 07:48:28 AM »
Daniel, I get tired just reading about all that "fun".  cooldude
« Reply #13 on: July 31, 2015, 01:27:29 PM »
And here I thought Daniel was going to post about the worms in the water supply.......
http://www.chron.com/houston/article/Worms-infest-Houston-suburb-water-supply-6415176.php
Surprised Serk didn't post it before me....
Hay  Cool
« Reply #14 on: July 31, 2015, 01:45:56 PM »
Hay  Cool
 Shocked  Shocked  Shocked  Shocked  Shocked
What happens in Houston, STAYS in Houston!
And there are some things Serk doesn't wanna know about!
Daniel Meyer
« Reply #15 on: August 01, 2015, 05:02:05 PM »
Built the first box beam today. Hope to install it tomorrow...
http://theoldvictorian.com/2015/08/01/boxing-wompy-jaws/
CUAgain,
Daniel Meyer
« Reply #16 on: August 01, 2015, 05:48:26 PM »
Looks beefy enough to me  cooldude But I'm no builder either.  How does one make a curved beam ? Hopefully you won't have to.
Daniel Meyer
« Reply #17 on: August 01, 2015, 06:08:29 PM »
Laminating (gluing) thin sheets of plywood together in the shape you want.
I hope I don't have to as well!
CUAgain,
Daniel Meyer
HurstRob
« Reply #18 on: August 02, 2015, 06:56:52 AM »
curved beams; build a templet and glue and laminate it to required thickness, screws and flitch plate should help and always a bit wider if you have the room.
Daniel Meyer
« Reply #19 on: August 03, 2015, 11:40:42 AM »
First segment installed.
spoiler: Nobody died.
http://theoldvictorian.com/2015/08/03/first-segment-installed/
CUAgain,
Daniel Meyer
Cracker Jack
« Reply #20 on: August 03, 2015, 01:28:45 PM »
Looks good and looks plenty strong for the application. However, that being said, it is not a true "box beam" in that there is no web providing a shear connection between the top and bottom segments. A true box beam would be over 4 times as stiff as what you ended up with. cooldude
Daniel Meyer
« Reply #21 on: August 03, 2015, 03:17:00 PM »
Can't put the "web" in AND still install it (needs to be screwed to the rafters). Will probably add one or two...but it IS actually a "box beam" as defined in the Victorian construction methods. They built them like this then covered the beams with 1" x 12" cedar tongue and groove mounted diagonally.
CUAgain,
Daniel Meyer
Cracker Jack
« Reply #22 on: August 03, 2015, 04:12:05 PM »
I apologize for being somewhat argumentative. I'm not familiar with Victorian construction methods.
It's not a box beam if the box is not complete (yours is not as shown). I'm not sure I understand how the 1" x12" cedar is applied but it could be applied in such a manner as to provide the necessary shear to complete the box structure and would become a critical part of the beam.
As I stated earlier, it appears to be plenty strong for the application and I realize you can call it whatever you like. Just calling it a box beam simply does not make it a box beam as used in a structural design application.  Roll Eyes
Daniel Meyer
« Reply #23 on: August 04, 2015, 09:48:03 AM »
Heh...ME calling it a box beam construction isn't what makes it a box beam construction.
I didn't coin the term. This was actually called "box beam construction" in 1890-1900 when the house was built. It was somewhat revolutionary...previously they would have just horked a big honkin' timber up there. I don't know when diagonal interior components came along...I'm sure that was just as revolutionary.
If the definition has changed so be it, but it doesn't change what it was called back then.
This house has mixed methods...these beams where loads weren't all that big...and big honkin' timbers everywhere else.
Not sure what they called "Big Honkin' Timber" methods in 1900.
CUAgain,
Daniel Meyer
Cracker Jack
« Reply #24 on: August 04, 2015, 05:48:05 PM »
Daniel Meyer
« Reply #25 on: August 10, 2015, 10:53:36 AM »
In this episode of "What's holding that up?"
It was 104 degrees and I got the shakes so I didn't get as far as I'd liked to this weekend.
http://theoldvictorian.com/2015/08/10/porch-box-beams-segment-two/
CUAgain,
Daniel Meyer
« Reply #26 on: August 10, 2015, 12:22:30 PM »
Were it me, I would have actually boxed it in with plywood or OSB, or perhaps just on one side, using sub-floor adhesive to unify the structure.  But then, I haven't studied construction methods from that era.
Daniel Meyer
« Reply #27 on: August 10, 2015, 01:02:28 PM »
Well it does get a covering...and that will have the effect. They would have used western red cedar planks on the outside, and they used strips of beadboard on the inside.
CUAgain,
Daniel Meyer
Wizzard
Bald River Falls
Valparaiso IN
« Reply #28 on: August 10, 2015, 01:23:25 PM »
My house was built in 1898 and when I remodeled it had real logs for beams in the floor with bark still on them. All the 2x4 and 2x6 were real oak and were full 2x4 and 2x6. I had to drill every nail hole. Then I had the house jacked up and dug a full basement underneath with a 13 foot ceiling. House was in the air and no running water and only kerosene stove for heat during the winter for 3 months. Had 3 little kids. Surprised my wife stuck with me.
I feel you pain Daniel
Oh and my kids brag about how they used an outhouse I rented in the winter. They had to walk down a plank 13 feet over the dug basement till we got the walls poured.
VRCC # 24157
shortleg
maryland
« Reply #29 on: August 10, 2015, 01:50:56 PM »
  As far as What,s holding that up?
I would say strong worms!!!!!!
      shortleg
Daniel Meyer
« Reply #30 on: August 31, 2015, 11:18:33 AM »
Framing done...
http://theoldvictorian.com/2015/08/31/a-porch-is-a-porch-of-course-of-course/
CUAgain,
Daniel Meyer
Daniel Meyer
« Reply #31 on: November 09, 2015, 09:27:13 AM »
"The math was actually pretty simple:
U + fucca + this + up = bigHonkin $$$"
http://theoldvictorian.com/2015/11/09/column-prep-part-the-first/
CUAgain,
Daniel Meyer
« Reply #32 on: November 09, 2015, 09:48:52 AM »
Been raining here in Atlanta for about the past 2 weeks.
I like my method of remodeling.
Get large check from insurance company for house fire.
Find general contractor.
Give him a little money to get started.
Get everyone to agree to my decision about changing the 1st and 2nd floor plans .
Drive  by every 2 days to inspect progress.
Crack whip to keep things moving along whilst drinking mint juleps and humming negro spirituals.
If I'd tried to actually do the work as Daniel is the house would get condemned.  Grin
Daniel Meyer
« Reply #33 on: November 17, 2015, 05:41:28 PM »
Two columns installed...
http://theoldvictorian.com/2015/11/16/one-two/
CUAgain,
Daniel Meyer
