November 23, 2025, 02:21:13 PM *
Author Topic: OEM Oil/filter and air filter  (Read 605 times)
kahnma
Austin, TX
« on: July 30, 2015, 07:01:54 AM »
Can someone post a link to purchasing the OEM air filter, Honda oil and Honda oil filter? I am not trying to be lazy, i just dont see part numbers posted and had a hard time figuring out the exact parts i need through the internet.
Thanks!
2001 Valkyrie
2014 KTM 500 EXC
« Reply #1 on: July 30, 2015, 07:36:26 AM »
http://www.servicehonda.com/parts/lookup#/Honda/GL1500CT_A_(97)_MOTORCYCLE%2c_USA%2c_VIN%23_1HFSC343-VA000001/AIR_CLEANER/GL1500CT-97-A/2Y14MZ0VE1AMZ04F1900A
               17210-MZ0-000   AIR CLEANER     $17.21
http://www.amazon.com/Honda-4-Stroke-Motor-10W-40-CASE/dp/B000LZEKHS/ref=sr_1_7?ie=UTF8&qid=1438267313&sr=8-7&keywords=honda+gn4+motorcycle+oil
http://www.amazon.com/Honda-OEM-Oil-Filter-HONDA/dp/B003O784DQ/ref=sr_1_1?ie=UTF8&qid=1438267187&sr=8-1&keywords=oem+valkyrie+oil+filter
Moonshot_1
« Reply #2 on: July 30, 2015, 07:51:32 AM »
Not trying to be lazy? How can you not try to be lazy? Not trying to be lazy is the ultimate definition of lazy. I mean doesn't "not trying to be lazy" mean that you are not even trying to do nothing?
(Sorry, can't pass up straight lines) crazy2
Mike Luken
Cherokee, Ia.
Hooter
S.W. Michigan
« Reply #3 on: July 30, 2015, 08:01:21 AM »
                                              "I'm not trying to be lazy".
                                                        I am!   cooldude
kahnma
Austin, TX
« Reply #4 on: July 30, 2015, 08:09:40 AM »
I am definitely lazy, but i just found this awesome site that has all part numbers to most parts we need for our valks and aftermarket information as well! It just helped me a lot, i hope it helps others!
http://www.valkyrienorway.com/partsbrake.html
2001 Valkyrie
2014 KTM 500 EXC
Momz
ABATE, AMA, & MRF rep.
« Reply #5 on: July 30, 2015, 08:52:59 AM »
Why use OEM oil and filters?
All three of my Valks have K&N air filters.
I only use Shell Rottela T6 oil in my bikes (good practice).
I have used "SuperTech", "K&N", and yes,.....OEM oil filters.
ALWAYS QUESTION AUTHORITY!
kahnma
Austin, TX
« Reply #6 on: July 30, 2015, 08:58:41 AM »
No particular reason to be honest, i figure OEM isnt going to be the most performance but wont screw anything up either... That's good enough for me.
2001 Valkyrie
2014 KTM 500 EXC
Steve K (IA)
Cedar Rapids, Iowa
« Reply #7 on: July 31, 2015, 11:29:17 AM »
Of my 2 Valks...the I/S I bought new and all the while it was on warranty, I used only Honda oil and filters so if anything mechanical might have occurred, they couldn't blame it on my choice of oil and filters.
Ever since that warranty expired, I use Rotella T6 and just switched to yellow Purolator filters (painted flat black).
States I Have Ridden In
