November 23, 2025, 02:16:56 PM
98 Left side cover.
Topic: 98 Left side cover. (Read 427 times)
slabghost
Eastern Ohio
98 Left side cover.
August 07, 2015, 12:06:59 AM »
Seems the front tab is broken on my new to me bike. Can anyone post a pic of that tab so I can try to fix mine? I looked on ebay for another cover or at least a good picture but no joy.
Politicians like diapers need changed often. And for the same reason.
If you aren't a liberal at 20 you have no heart. If you aren't conservative at 30 you have no brain.- Mark Twain
Hot air is great for balloons but worthless in conversation.
Re: 98 Left side cover.
August 07, 2015, 12:17:58 AM »
Do a search for side cover repair. Seems like there is one in shop talk, but I'm tooooo damn lazy to go look.
spud
London Ontario
August 07, 2015, 05:56:32 AM »
Had a 2001 Interstate. Tabs on the side covers were fragile.
I reinforced them with epoxy. Still broke one off.
Dealer had covers but too much money.
Took some Velcro and pasted one to the inside of the cover
and the other fuzzy side to the bike. Never had a problem.
spud.
August 07, 2015, 06:10:35 AM »
When removing the side covers, you don't pull straight out on them. That will bust the tabs quite easily. Pull the back end loose first and kinda swing it out slightly, then disengage the front tab. It has a hook built into it and if pulled straight out, sooner or later that hooked end or the slot it goes in will snap.
GiG
NEAR the "In 'n' Out Burger"
August 07, 2015, 07:44:01 AM »
Years ago, someone posted a fix involving a large staple epoxied to the inside of the side cover. The staple replaced the broken tab. Maybe that post still exists on Tech Board...
One of my Valks has the Velcro fix and it works pretty well...
Everything is - Nothing is .
(send it to OSS)
This isn’t Rocket Surgery
August 07, 2015, 09:31:47 AM »
The repair information is there to be found, and I'm as lazy as RJ when it comes to searching for answers to really common problems for other people. I fixed mine using JB Weld and a paper clip bent and cut appropriately to use as rebar.
Reply #6 on:
August 07, 2015, 09:44:57 AM »
http://www.vermin-club.org/mods/side_cover_tab_repair.htm
http://www.valkyrieforum.com/bbs/index.php/topic,7332.0.html
slabghost
Eastern Ohio
Reply #7 on:
August 07, 2015, 04:35:05 PM »
Thank you for the links! It's just what I was looking for. I did a few searches and missed both of those and read a few how to's in the tech section.
=> InZane XXV
