November 23, 2025, 02:42:05 PM *
Author Topic: Shoe inserts  (Read 815 times)
Jersey mike
Brick,NJ
« on: August 07, 2015, 07:09:26 PM »
This is a real off beat topic but does anyone use shoe inserts?  I bought a pair of Icon El bajo riding boots online and they are a 1/2 size too big. I ordered another pair in a smaller size and I'm waiting for them to arrive.
If the smaller size is too small, I'll keep the first pair because with a better pair of socks they were a little more snug, but if I can find a good insert that should complete the fit.
I've worn some inserts in the past but they all seem to bunch up or get twisted up in my shoe before long so I thought I'd see if anyone had suggestions. I have 30 days to return if I can't get a good fit.
« Reply #1 on: August 07, 2015, 07:28:22 PM »
I use them in my work boots. The ones that are kind of like neoprene stay in place well.
BobB
« Reply #2 on: August 07, 2015, 07:35:49 PM »
I've used gel sole inserts in motorcycle boots but now I've just found a comfortable boot that fits.
I been in TourMaster Solution 2 touring boots for three years.  They feel good on the bike and you can walk in them all day...
PAVALKER
Pittsburgh, Pa
« Reply #3 on: August 07, 2015, 07:39:01 PM »
Go to Walmart and stand on the Dr Scholls machine, see if those do the trick for ya.  If not, put insoles under the Dr Scholls inserts.
Edit.....  You might want to remove the original inserts, then insert  some cheap others under the originals to add the space needed.
« Last Edit: August 07, 2015, 07:42:10 PM by PAVALKER » Logged
John
big poppa pump
San Antonio, TX
« Reply #4 on: August 08, 2015, 01:44:13 AM »
Use this in all of my riding boots since I have high arches. Gives me a very snug fit without any discomfort.
http://www.drscholls.com/productsandbrands/Products/painrelieforthotics/index.aspx
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #5 on: August 08, 2015, 06:57:37 AM »
My two best pair of bike specific boots came 1/2 size too big, because I'm a cheap bastard and got both on big sales (expensive boots for half price)(a half size up on normal D width are about right for my EEE wide feet).  They are best for cold weather when double sox make them a near perfect fit.
But I run Spenco Polysorb in ALL my footwear.  They sell a wide selection, and all of them are fine.  They stay put, don't slip, and last for years.  If they must be trimmed at the toe, do little by little, too much and your toes go over an edge and that is not good.
They just about make a half size large a perfect fit, except the toe will always be a tad long.
http://www.amazon.com/Spenco%C2%AE-PolySorb%C2%AE-Cross-Trainer-Insoles/dp/B000GCLT4I/ref=sr_1_1?ie=UTF8&qid=1439042813&sr=8-1&keywords=spenco+polysorb
http://www.amazon.com/s/ref=sr_pg_1?rh=i%3Aaps%2Ck%3Aspenco+polysorb&keywords=spenco+polysorb&ie=UTF8&qid=1439042976&spIA=B00EFUM1HQ,B005FZJNP8,B00EFTJ5OE,B00EFW8MEK
« Last Edit: August 08, 2015, 07:01:04 AM by Jess from VA » Logged
