November 23, 2025, 08:00:20 AM *
Author Topic: Sissy Bar backrest to grab bar....Help  (Read 338 times)
Roidfingers
Tuscaloosa, Alabama
« on: September 24, 2015, 07:23:03 AM »
Im not sure what manufacturer of my passenger back rest is, but Im trying to find a grab bar that goes from the 2 side mounts where the upper sissy bar slides down into. Any one know of such a thing? Ive removed the sissy bar from the mounts via 4 bolts. Two on each side. Wondering if they make a short U shaped piece that is short that would fit in where the backrest came out.
Gary
Northern New Mexico
« Reply #1 on: September 24, 2015, 07:32:10 AM »
If it's the stock Honda sissy bar set up it sounds like you're looking for a solo cruise bar (or something similar). Check the Classifieds section on this board, I just sold one I had on hand not being used.
Not sure if they make them new anymore but I'm sure someone will chime in.
Good luck!
Roidfingers
Tuscaloosa, Alabama
« Reply #2 on: September 24, 2015, 07:38:27 AM »
 cooldude Thanks. The backrest pad has a big V stitched into it. Not sure if that's the stock one or not. It measures 8 and 3/4 inches across from top of mount to top of mount.
« Reply #3 on: September 24, 2015, 08:20:31 AM »
This?
http://www.bigbikethings.com/CruiserBar.html
-Cankerelbow
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: September 24, 2015, 09:07:44 AM »
 Grin Thank you Hubcapsc !!!! That's it. got it on order already. Thank you so much. Tried to search online but sometimes your not sure what they are called. HAHA. Thanks again.
