« on: December 01, 2015, 04:07:29 PM » |
I know some guys like to use the winter months to swap out the fluids.
For those that want to stay with DOT 4, I found a qt bottle at Advance Auto for $4.99.
They also have Seafoam with a $5.00 discount on 2 bottles.
« Reply #1 on: December 01, 2015, 04:51:20 PM » |
And here I thought you had some formula to mix them together.
Pepmyster
Go Bonzo, Go!!!!
Mascouche, Quebec, Canada
« Reply #2 on: December 01, 2015, 05:02:27 PM » |
Now this is getting interesting........
« Reply #3 on: December 01, 2015, 05:10:27 PM » |
I suppose you could w/o dying, but what would you use it on, or in?
« Reply #4 on: December 01, 2015, 06:46:54 PM » |
Ice.... and shaken not stirred, of course.
Hooter
« Reply #5 on: December 02, 2015, 04:26:37 AM » |
I use Sea Foam religiously in everything I have. One store has it for $11.00 and you go down the road a half mile and get it for $7.00. The store at $11.00 wonders why it doesn't sell and the $7.00 store can't keep it in stock. I told the owner of the $11.00 store to send someone to the other store and he would be able to figure it out. The money grubbin ass he is.
« Reply #6 on: December 02, 2015, 06:11:32 AM » |
Yep, I find that Sea Foam prices are all over the map. We all use it here and it works great for storage.
Pappy!
« Reply #7 on: December 02, 2015, 06:14:13 AM » |
Well, of course you would use the Seafoam to keep your Dot 4 clean while in the hydraulic system!
bill-jr
VRCC # 35094
murfreesboro
« Reply #8 on: December 02, 2015, 06:36:47 AM » |
Is there an option besides dot 4 ???
Ever danced with the devil In the pale moon light ? 99' Black tourer
« Reply #9 on: December 02, 2015, 06:44:46 AM » |
Is there an option besides dot 4 ???  I haven't looked into it that much, but DOT 4 has been harder to find, for some reason, and supposedly there's a HYBRID out there. I've heard DOT 5 is available. Maybe the hybrid or DOT 5 is better? Don't know. But DOT 4 works and I found it at 5 bucks for a Qt and thought I'd pass the info on.
« Reply #10 on: December 02, 2015, 07:50:28 AM » |
A few years ago (2-3) advanced auto parts had one of those coupons online available and I picked up in store a gallon jug of seafoam vs. just the 16 ounce can is all. It was a lot cheaper to do it that way and still have about 1/2 the big white jug left of seafoam.
Does seafoam have a shelf life once opened or not opened?? I would not think so, but stabil has a shelf life that I know since after a few years it can have particles inside floating around, not good.
« Reply #11 on: December 02, 2015, 08:11:05 AM » |
Is there an option besides dot 4 ???  I haven't looked into it that much, but DOT 4 has been harder to find, for some reason, and supposedly there's a HYBRID out there. I've heard DOT 5 is available. Maybe the hybrid or DOT 5 is better? Don't know. But DOT 4 works and I found it at 5 bucks for a Qt and thought I'd pass the info on. only use DOT 4 with the highest wet boiling point. I've posted before brands to get. never use DOT 5 not compatible with any other type fluid. the hybrid is DOT 5.1 and is for ABS systems, different viscosity vs DOT 4. is compatible with DOT 3 and 4. due to viscosity might not provide same braking performance in a non-ABS system from what I've read. I presently have not seen any actual testing to back that up.
« Reply #12 on: December 02, 2015, 08:11:53 AM » |
Is there an option besides dot 4 ???  This is what I get at advance...  -Mike
bentwrench
« Reply #13 on: December 02, 2015, 02:22:26 PM » |
Advanced Auto in my area is really stepping up.they have M/C plugs at the same as I've found online,syn.bike oils,filters and even chain lube for my other bikes.Getting to be regular stop for me.
« Reply #14 on: December 02, 2015, 03:45:25 PM » |
Is there an option besides dot 4 ???  I haven't looked into it that much, but DOT 4 has been harder to find, for some reason, and supposedly there's a HYBRID out there. I've heard DOT 5 is available. Maybe the hybrid or DOT 5 is better? Don't know. But DOT 4 works and I found it at 5 bucks for a Qt and thought I'd pass the info on. only use DOT 4 with the highest wet boiling point. I've posted before brands to get. never use DOT 5 not compatible with any other type fluid. the hybrid is DOT 5.1 and is for ABS systems, different viscosity vs DOT 4. is compatible with DOT 3 and 4. due to viscosity might not provide same braking performance in a non-ABS system from what I've read. I presently have not seen any actual testing to back that up. I went back and checked out your old posts, good info. Also, this is good info originally posted by Rio Wil http://www.lelandwest.com/brake-fluid-comparison-chart.cfmFor my use, the fluid I bought will be just fine, as I plan on continuing to changing it out every 2 -3 years. With 3 bikes to do, I'll probably need all of a qt or more. Basically, I've learned not to stockpile it like oil or grease, as it has a shelf life, even before opening the container.
« Reply #15 on: December 02, 2015, 06:31:05 PM » |
Is there an option besides dot 4 ???  I haven't looked into it that much, but DOT 4 has been harder to find, for some reason, and supposedly there's a HYBRID out there. I've heard DOT 5 is available. Maybe the hybrid or DOT 5 is better? Don't know. But DOT 4 works and I found it at 5 bucks for a Qt and thought I'd pass the info on. only use DOT 4 with the highest wet boiling point. I've posted before brands to get. never use DOT 5 not compatible with any other type fluid. the hybrid is DOT 5.1 and is for ABS systems, different viscosity vs DOT 4. is compatible with DOT 3 and 4. due to viscosity might not provide same braking performance in a non-ABS system from what I've read. I presently have not seen any actual testing to back that up. I went back and checked out your old posts, good info. Also, this is good info originally posted by Rio Wil http://www.lelandwest.com/brake-fluid-comparison-chart.cfmFor my use, the fluid I bought will be just fine, as I plan on continuing to changing it out every 2 -3 years. With 3 bikes to do, I'll probably need all of a qt or more. Basically, I've learned not to stockpile it like oil or grease, as it has a shelf life, even before opening the container. Thanks, that is a great link from Rio. I picked up the Pentosin, its in a metal can, NAPA carries it. The ATE brand is considered one of the best for the $$$, high wet point allows a change out up to 4-5yrs.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #16 on: December 03, 2015, 02:25:07 AM » |
Is there an option besides dot 4 ???  This is what I get at advance...  -Mike Same here
