November 22, 2025, 02:36:37 PM *
Author Topic: Tie downs... NOW I'm confused...  (Read 1389 times)
CajunRider
Broussard, LA
« on: December 21, 2015, 04:41:36 PM »
I've been told multiple times that one should NOT use the engine guards as a tie down point when trailering... but I noticed that Honda actually crates the bikes this way?????
So is this OK or is it NOT OK????
Referenced post:  (Hope you don't mind me using this, Dave)
http://www.valkyrieforum.com/bbs/index.php/topic,83388.0.html
Picture (note the tie down points):
Sent from my Apple IIe
« Reply #1 on: December 21, 2015, 05:07:00 PM »
That's how RJ always said to do it.
Hooking to the wrong place on the handlebars
is asking for trouble, if you put the hook someplace
that has leverage that might make the handlebars
spin in the riser clamps...
« Reply #2 on: December 21, 2015, 05:17:30 PM »
I've had the crash bars off of my I/S and with the way they are mounted I have ZERO problem using them when I trailer. I'd PREFER to go over the handle bars but there IS lotsa "stuff" in the way on an I/S. RIDE SAFE.
« Reply #3 on: December 21, 2015, 05:18:05 PM »
Thats good enough for me.  Smiley
PAVALKER
Pittsburgh, Pa
« Reply #4 on: December 21, 2015, 05:54:38 PM »
Recommend you check torque on upper shock bolts when you take delivery.  Honda uses those to as tie down points but sometimes the dealer doesn't re-torque those or use loctite.  I lost an upper shock bolt and the shock came off in a turn and jammed itself up in under the seat.  It was a VTX1800.
John
« Reply #5 on: December 21, 2015, 06:24:41 PM »
Although many do it, I never use the engine guards for a tie down point. I observed first hand the top one snapping off when the driver hit some construction areas without warning. The bike turned into an 800 lb. loose cannon. I always use two straps on each side over the bottom tree, one is tied off forward, thereby holding the bike into the built-in wheel chock in my trailer. The other is straight off to the side, both snugged down with a slight fork compression. I remove the seat and hook a strap around the frame just behind the "Y" near the back end of the tank, then hook into it another floor mounted tie down that's slightly forward. That one I ratchet down tight. As a result, when a friend used my method and got knocked off the road near Dallas some years ago, his trailer got dumped on its side but the bike never moved. When it comes to tying a bike down, always use the frame wherever/whenever possible. Since the steering stem is nearly the same size as the frame members I have no issue using the lower tree as a tie down point. But the bolts used on the engine guard and rear guards will, and have, snapped. Repairing that with a bolt snapped off flush....have fun.  Wink
Ice
On a road less traveled.
« Reply #6 on: December 22, 2015, 04:49:44 AM »
When I shipped my Valk to Germany and back again I used the engine guards to strap the beast down, never had an issue. I actually prefer to tie her down there, less stuff to pinch or jam while tightening the straps.
LL
Flower Mound TEXAS!!!!!!
« Reply #7 on: December 22, 2015, 05:10:16 AM »
Even though the Honda dealer I use said he always ties off to case guards, he also says he buys auction bikes that have broke loose from crates supported off case guards.
 I can tell you this, once you see your own bike supported off case/crash bars and their bolts have sheared off (doesn't matter if they are grade 8 either, the frame isn't grade Cool, you will begin using soft-ties off the lower triple trees with the front wheel in a chock on the front end, and the rear end will be supported either thru the frame or around the rear wheel to keep it from bouncing around.
VRCC #472
« Reply #8 on: December 22, 2015, 05:58:14 AM »
I tie off the crash frame first, then back it up with the bars.
Got to be careful with the bar straps, as they will snap off the turns signals. Embarrassed
One year I took the Amtrak from Washington to FL for a wedding.  I only had a week and I didn't want to spend 4 days on I-95.  It was very cool.
What I learned from them was to double up the straps.
« Reply #9 on: December 22, 2015, 06:29:30 AM »
When I transport my ATV's,  I always use the front/rear racks and compress the suspension both front/rear.  However, they say it is best to frame mount on both fron/rear and let the suspension do the work bouncing up and down.
I don't think it matters either way to be honest, both will work, as long as you have 4 straps 2 in back and 2 in front secure.
I would think though the crash bar in front is fine thus allowing the front suspension to work up/down as intended and less chance of the fork seals going bad from overtightening using the handlebars.
Tightening down the rear suspension is not as vulnerable to problems compressing the rear shocks as it is the front fork seals but could use the frame as well in back vs. compressing rear shocks.
If I was trailering with a good wheel chock in the front tire,  it would be similar to what Dave's new Wing in the crate looks like.
Daniel Meyer
The State of confusion.
« Reply #10 on: December 22, 2015, 09:53:07 AM »
Strapping a valk....I've heard the term...but I don't understand what it means Smiley
CUAgain,
Daniel Meyer
« Reply #11 on: December 22, 2015, 10:07:04 AM »
I think it involves padded handcuffs, a nice bed, and a willing Valkyrie...
Oh wait, are ya'll talking about Valkyrie motorcycles??
CajunRider
Broussard, LA
« Reply #12 on: December 22, 2015, 04:07:37 PM »
 2funny   2funny   2funny
Only time I tied down the Wing was when a forest critter took out my radiator at 85 mph.    Shocked
Pappy!
Central Florida - Eustis
« Reply #13 on: December 22, 2015, 05:02:39 PM »
.....85mph? That's a fast forest critter !
Dave Ritsema
South Bend IN
« Reply #14 on: December 22, 2015, 07:52:29 PM »
No worries.  Smiley
As others have said, I have always followed RJ's advice and used the front case guards. I will tell you that the one time I put my F6B on a trailer and used the case guards they did flex a bit and were not as substantial as the Valkyrie was. I had no problems in either case however.
VRCC 2879
Lake City Honda Warsaw IN
