November 22, 2025, 08:52:34 AM
I've never had that happen before
Topic: I've never had that happen before (Read 492 times)
January 09, 2016, 07:20:43 AM »
Rented a 17 foot U Haul to pick up some furniture.
On the way to return it stopped at Exxon to put some gas in.
Put gas pump nozzle into gas tank filler hole.
Pulled trigger on pump handle and gas poured onto the ground below the vehicle.
Pulled nozzle out and firmly reinserted.
Same result.
Whydiditdidat?
Jess Tolbirt
White Bluff, Tn.
Re: I've never had that happen before
January 09, 2016, 07:29:59 AM »
truck used to have 2 tanks and the filler u used went nowhere,, you should have used the filler on the other side
January 09, 2016, 08:37:02 AM »
Quote from: Jess Tolbirt on January 09, 2016, 07:29:59 AM
Surely they wouldn't have left a functioning screw off gas cap with "use regular gas" sticker on it over a void???
January 09, 2016, 03:03:06 PM »
Someone would have to take a look, but, it sounds as though the tube and connecting tubes are the problem. Probably one of the rubber connector hoses went bad. It shouldn't be too hard to see what the problem is.
msb
Agassiz, BC Canada
January 09, 2016, 06:07:30 PM »
About 10 years ago I had a new Chev 1500 truck, and was broadsided by a moving van the day before I was to leave on holiday to Mexico with the family. Got the truck towed in to a shop and an insurance claim started then left for Mexico the next day. When I returned my truck was repaired, and when I picked it up the tank read empty so I stopped to fill it up. Same thing happened...gas poured onto the groud under the truck...body shop forgot to install the gas filler hose.
'99 Red & Black IS
Mr Whiskey
January 10, 2016, 12:01:22 AM »
Sounds like someone cut the tube under the truck
to get a siphon hose in the tank
Peace, Whiskey.
=> InZane XXV
