November 22, 2025, 03:11:51 AM *
Author Topic: Kury Intake/Spark Plug Covers  (Read 432 times)
PAVALKER
Pittsburgh, Pa
« on: February 03, 2016, 04:43:58 PM »
I changed the intake O-Rings today and took that opportunity to also install  Kury Intake/Spark Plug Covers.  However, since I have an Interstate, with Pod Lights, I had to modify the covers in under the POD area.  Looks good..... but I was curious if Kury ever made those specifically for the Interstate as well as the ones for the Standard/Tourer?
John
« Reply #1 on: February 03, 2016, 04:56:00 PM »
Yes, one side is shorter but you can modify a regular set the same way....cut it shorter. Forget which side it is without going out and checking the bike. Not a big deal, been done many times before.
PAVALKER
Pittsburgh, Pa
« Reply #2 on: February 03, 2016, 05:05:04 PM »
Yep....Thanks...  just found that it is part 7706 vice 7705.  I could not find any listed for sale, but just now googled Kury part numbers on either side of the 7705 and found it.  I had this one sitting on the shelf for a year or two and guess I couldn't find one back then either.  Just had to trim it about an inch on each one in the forward section to clear POD light brackets.
Thanks.
John
« Reply #3 on: February 03, 2016, 05:21:07 PM »
I have Standard / Tourer  on my Interstate I didn't cut anything.
PAVALKER
Pittsburgh, Pa
« Reply #4 on: February 03, 2016, 06:00:41 PM »
You had to take the pods off to put those on, like I did also.  But, I have POD lights and the brackets clamped to the engine guards under the PODs interfere with them and they would not go on.  I had to trim about an inch off the front ends of both pieces.  Really can't see that far up behind the POD toward that bracket.
But.....maybe that is why I bought those years ago, knowing they would fit the IS as well as the others.
John
« Reply #5 on: February 03, 2016, 06:23:03 PM »
I wish I had bought the POD lights back in the day and some custom RC wheels when they was making them for the Fat Girl.
