« on: February 13, 2016, 03:13:26 PM » |
> Subject: The Female > Urologist > > > NO WONDER SO MANY OLDER GUYS > BELIEVE THEY HAVE > > > PROSTATE > PROBLEMS!!! > > > An old guy goes to > his doctor for his physical and gets sent to > the Urologist as a precaution. When he gets > there, he discovers the Urologist is a very pretty > female doctor. > > The female doctor > says "I'm going to check your prostate today, > but this new procedure is a little different from > what you are probably used to. I want you to > lie on your right side, bend your > knees, then while I check your prostate take a > deep breath and say '99'. > > The old guy obeys and > says"99". > > The doctor says, > "Great", now turn over on your left side and > again, > while I repeat the check, take a deep breath and say > "99". > > Again, the old guy > says '99'. > > The doctor says, > “Very good. Now then, I want you to lie on > your > back with your knees raised slightly. > I'm going to check your prostate with this hand, > and with the other hand I'm going to hold > on to your penis to keep it out of the way. Now > take a deep breath > > and say > '99'. > > The old guy begins, > > > One.... > > > two… > > > three… > > > > >
