I'd recommend a Shinko but many wouldn't.
I'd recommend OEM pads.
I've tried all but Avon front tires.....mainly because I remember you had a bad run of them on the front......Avon is the only tire I run on the back......I tried an E3 on the front one time......it was noisy from day 1 to the last day.....Longevity on the rear tires are Avon-8k-9.5Kish miles.....Metz's around 6K......
Definitely going with OEM brake pads.......seems like I buggered up that pin hanger plug the last time I changed the rear pads.....
