News:
Main Menu
UDS
Started by hukmut, Fri 16, Sep 2016, 17:10:07
Previous topic - Next topic
hukmut
I know that most, if not all of you, like to partake in some form of smoked meat. I have found a quick (and relatively) inexpensive way to make your own smoked delicacies. A 55 gallon steel drum. I built mine for less than $50. I don't have a link, but just google (or your choice of search engine) barrel smokers, how to make. Man, chicken takes on a whole new flavor spectrum. Can't wait to do a brisket or rack of ribs. If you are down this way, south Mississippi, let me know and we will eat copious amounts of smoked heaven. And, yes, there will be cold adult beverages to wash it down. :cooldude:
Ride safe, y'all!!!
Jess Tolbirt
barrels are made of wood, drums are made of metal
Valkyrie member # 23084
Drums, barrels it doesn't matter. The only part that matters is the smoking. Are you doing any brining also ? Smoked fish is good also.  :cooldude:
hukmut
I am currently just smoking chicken. Brining is the next thing. I have a real good recipe for a rub.
My neighbors have remarked that it smells fabulous and the smoke "hangs" in the trees.
I am gonna try a Boston butt tomorrow, even if it rains. I also have a set of rods that I can hang whole
hunks of meat on to soak up that wonderful smoke.
If I could figure out how to post pictures, I would. But, really, the pictures would not even come close to
describing the odors or the flavors.
OK. Enough.
Y'all ride safe!   :cooldude:
DK
Are you cold smoking & then cooking?
If you are smoking & cooking simetaneously, how are you doing the temperature?
baldo
Quote from: hukmut on Sat 17, Sep 2016, 07:41:25
:o :o :o :o
Quote from: DK on Sat 17, Sep 2016, 08:28:14
Don't know how he is doing it but I smoke a lot of meat and when doing Butt I keep mine  between 250/275 and you have to set the whole day aside because it takes 10/12 hrs depending on the lbs of the Pork Butts but well worth the effort :cooldude:
hukmut
#7
It is almost a set it and forget it type of cooking. The thing cooks and smokes simultaneously. Temps run from 250-275 early on ( the first few hours) and then tend to get hotter. But by then the chicken is done. Takes a little preplanning, but its really not that big of a deal. 2 1/2 hours for a couple of chickens. End temps internally are between 170-190 degrees. Plenty done without drying out the meat.
And again, this thing only cost me about a days work to put together and about $50. Twenty- five for the container and the paint for the outside was eleven. The rest was for the hardware. I scrounged the expanded metal for the coal basket. No welding was required.  I used a weed burner to burn out the internal coating and scrubbed it clean and then cooked a pound of sausage to "season" the inside.
Temps are controlled by covering the 4 holes near the bottom for intake air with magnets.  Leave all 4 open to get up to cooking temp and then cover 2 or 3 with magnets to regulate.
There are 8 three-quarter inch holes in the lid that allow for exhaust. Leave them open. This thing is easy to operate and the results are fabulous. I am surprised.
There are several forums to peruse for recipes. :cooldude:
