jdp
« on: September 17, 2016, 05:41:37 PM » |
I have an interstate and always thought it leaned over too much and I parked next to another interstate the other day and mine does lean over too much, I checked everything and it looks fine, even when I put the kick stand up it looks right up next to the exhaust, has anyone had this problem? I put a block of wood under the stand to bring t up alittle, I could weld a small piece of metal to the bottom but that would look bad.
« Reply #1 on: September 17, 2016, 05:47:05 PM » |
Make sure the cross member isn't bent, you don't want to fix the wrong problem
jdp
« Reply #2 on: September 17, 2016, 05:50:03 PM » |
Yeah I checked all that everything looks good, there is a lift adaptor that s mounted in between the cross member and kickstand do you think that might be the problem?
« Reply #3 on: September 17, 2016, 06:09:48 PM » |
I would think the addition of the adapter would do the opposite, lower the stand, should make it lean less.
Do you have OE size tires mostly the rear 180/70?
« Reply #4 on: September 17, 2016, 06:17:56 PM » |
The length of shocks will sometimes do that but I think that would show in a side by side comparison. It just takes a little extra height to make a deeper lean.
Otherwise someone may have tried to bend the stand enough to make up for the extra of the lift adapter?
jdp
« Reply #5 on: September 17, 2016, 06:39:55 PM » |
That might be it, the rear tire I have on is a 180/65
« Reply #6 on: September 17, 2016, 06:54:44 PM » |
Now, that there is puzzling. The shorter tire seems like it should again bring the stand to the ground sooner therefore, less lean. It's looking more likely the PO needed to do something to get her to lean more. Check the stand closely
jdp
« Reply #7 on: September 17, 2016, 07:03:43 PM » |
I have a tour model here at my house, I'm going to switch kick stands and see what happens, also I'm going to put them side by side and see if I can see anything different , thanks for the help.
Hooter
« Reply #8 on: September 18, 2016, 03:44:43 AM » |
I wouldn't take one off, just measure them. Maybe the Tourer and the IS are different lengths?? Dunno.
« Reply #9 on: September 18, 2016, 04:22:58 PM » |
Was interested, because my IS leans too much, and it already has a "hockey puck" bolted onto it's foot. The 99 Tourer and IS have a different part number for the side stand. Put does it mean they are different?
Will need to find out. I don't have my stand from my wreck. I'm sure once I get a taller tire (Austin TT), I'll need to fix this problem. I see nothing wrong with my cross bar.
jdp
« Reply #10 on: September 18, 2016, 07:42:23 PM » |
Yeah I haven't found anything yet but Monday I'll probably switch kick stands and see what happens and get back with you.
« Reply #11 on: September 19, 2016, 07:35:45 AM » |
I'm thinking either the kick stand is bent or as Carl suggested, where it mounts is bent. One is easy to fix, the other, not so much. Shocks and kick stand length can make a difference but with the tires he's running, leaning over more is not an option, it should be standing up straighter. Either that or, you need to stop putting the kick stand down while over pot holes.
VRCC# 29981 Learning the majority of life's lessons the hard way.
Wizzard
Bald River Falls
Valparaiso IN
« Reply #12 on: September 19, 2016, 07:39:27 AM » |
I'm thinking either the kick stand is bent or as Carl suggested, where it mounts is bent. One is easy to fix, the other, not so much. Shocks and kick stand length can make a difference but with the tires he's running, leaning over more is not an option, it should be standing up straighter. Either that or, you need to stop putting the kick stand down while over pot holes.  Or on asphalt in 95 deg weather
 VRCC # 24157
« Reply #13 on: September 19, 2016, 07:42:05 AM » |
I'm thinking either the kick stand is bent or as Carl suggested, where it mounts is bent. One is easy to fix, the other, not so much. Shocks and kick stand length can make a difference but with the tires he's running, leaning over more is not an option, it should be standing up straighter. Either that or, you need to stop putting the kick stand down while over pot holes.  Or on asphalt in 95 deg weather  Well, there is that..................
« Reply #14 on: September 19, 2016, 07:49:57 AM » |
I have two 99 interstates, with no damged crossmembers or bent stands, and one leans noticably more than the other. It's a mystery.
« Reply #15 on: September 19, 2016, 10:13:08 AM » |
I may have solved the mystery, Jess you have the perfect situation to test my theory. I'm thinking play in the stand to mount joint could be a huge factor. Jess, if you could, with the bike on a lift or just supported without the side stand and put the stand in the down position and try lifting it up and down and see if one has more play than the other. Worth a shot
« Reply #16 on: September 19, 2016, 10:57:26 AM » |
I may have solved the mystery, Jess you have the perfect situation to test my theory. I'm thinking play in the stand to mount joint could be a huge factor. Jess, if you could, with the bike on a lift or just supported without the side stand and put the stand in the down position and try lifting it up and down and see if one has more play than the other. Worth a shot Jeff, I'm far from home up in Belleville MI with family (on one bike). I rarely get both bikes out at the same time, but I will try to remember to check this in the future. It's no big deal, except when I get my trunk bike out for the first time in months (it's the big leaner), when I put it on the stand, I think it's gonna fall over.
