November 20, 2025, 04:04:27 AM *
Author Topic: Questions about the Bell Mag-9 helmet  (Read 352 times)
Steel cowboy
Spring Hill, Fl.
« on: November 01, 2016, 01:05:08 PM »
Does anybody use this helmet, do you like it? I like the look of it. The helmet will accept a Sena 10, but will it accept a Sena 20?
« Last Edit: November 01, 2016, 01:11:55 PM by Steel cowboy » Logged
2001 black interstate
2003 Jupiter Orange wing
Pappy!
Central Florida - Eustis
« Reply #1 on: November 01, 2016, 05:12:52 PM »
Most helmets will "accept" a Sena 2O. They may not have the correct mount pad in the helmet mold but the Sena comes with enough different ways to mount that it can be done pretty easily.
sixlow
St. Augustine, Fl.
« Reply #2 on: November 01, 2016, 06:20:40 PM »
That is the helmet the wife and I use, we like them. visor, hidden sun shield, clear shield comes off. if dropped the plastic pivot points can break, a 20 dollar replacement part that keeps the clear shield in the full up position firmly. I ride without the clear mostly. I haven't ventured into the Sena world yet, I still enjoy my "quiet time".
« Last Edit: November 01, 2016, 06:35:02 PM by sixlow » Logged
Steel cowboy
Spring Hill, Fl.
« Reply #3 on: November 01, 2016, 07:45:26 PM »
The helmet is designed for a Sena 10, it has the cap on the side you remove to make it a custom install. But the manufacturer isn't sure if the Sena 20 is the same size unit as the 10.
