TPMS Tire Pressure Monitoring Systems Product Review
Started by Jersey, Fri 30, Dec 2016, 20:23:51
Previous topic - Next topic
Jersey
I'm an ol' school rider that enjoys doing most things DIY.  When I purchased my '99 Valkyrie Interstate I knew checking the tires for air would be more of a challenge... and as human nature goes, the inconvenience would probably result in me not doing it as much as should be done.  So I started looking around for a remote tire pressure monitor.
With my previous rides, I tended to be more diligent in checking tire pressure and also tried some of the various stop leak additives.  But in this case, I wanted something accurate that gave me the information I needed on the various rides.  Let's face it, losing tire pressure on a 1000+ pound setup isn't fun!
I came across RRR's TPChecker and liked the design at first glance.  Everyone will have their opinions, but the display is fairly compact, easy to read, and fully weatherproof (read waterproof).  While the Valkyrie does have some dash to work with, it's still not a lot of room.  So size was a factor and this seemed to fit the bill.
I'm a bit of a nerd at times so I was curious about the technical details and reached out to Gordon with questions.  While I haven't met him in person, from the emails it's clear he would be fun to chat 'gear' with.  Gordon gave me all the information I needed and the purchase was made.  He did ask me if I was interested in righting a review to help others understand what might be involved in the installation of this.  So I agreed.
After receiving the product, I was impressed with the easy to understand manual.  There are only two buttons on this, so as expected there's not a lot of complexity in using it.  Basically, once installed I never touch it.  No need. It gives me the info in the easy to read display.
The first challenge was deciding on the placement.  From the various photos you can see that each location had its pros/cons. Eventually I decided on a handlebar mount on the left side.
The wiring is VERY easy since it's only 2 wires: Power and Ground.  Can't get simpler than that!  I won't get into the various details on wiring since each bike and owner will have different preferences. However, one good thing to remember is this unit draws very little power so it can easily be connected to any power wire without fear of overloading the original circuit or wires.
The next thing needed was to install the remote sensors in the rims.  I did this myself.  I also grew up changing my own car and motorcycle tires decades ago because... well... that's what you did back then.  Working tire spoons is not difficult, but there is a technique.  With practice it is fairly straight forward and easy to do.  With that said.  I do recommend if you've never changed a tire, it wouldn't be smart to try and install these sensors as your first time out. Pay the few bucks and have your local shop do it for you.
If you are planning on doing this, remember to invest in good spoons and a few pieces of leather to avoid scratching the rims.  For my rims, it was fairly straight forward.  I just needed to break the bead seal on one side and make enough room to slide the sensor in place.  The instructions are VERY specific about how many of the supplied spacers to use.  Depending on the curve of the rime, different spacers will be necessary.  I found the instructions very easy to follow and clearly understood what to look for in the setup.  Most important! Each sensor is marked for FRONT and REAR.  Make sure you install them correctly so your display will match up.
You'll also need to invest in plenty of tire weights to compensate for the weight of the sensor.  Again, these can be easily found at most parts stores and online at Amazon or eBay.  Get more than you think you'll need.
After installing the sensor you'll need to balance the tire.  There are plenty of balancing tools to be purchased online or at your local discount tool supply store.  However, I always found it easier to suspend the tire on its axle.  Make sure the axle is level so as not to throw off the turning of the tire.
The theory is that when the tire is balanced it will stop turning at different points.  In practice, even a well-balanced tire will tend to stop at the same location... it's not as much WHERE the tire stops, but how it settles.  Does it quickly turn back-and-forth like a pendulum?  Does it slowly, almost randomly come to a stop without a pendulum action?  These are things to look for and part of the learning experience in using this technique. The key is patience.
To start – suspend the axle between two chairs or whatever you have and use a level to verify that it's, well, level.  Slide your tire over the axle and suspend it.  Spin it a few times slowly to make sure it's stable and won't move off its mark.  Next slowly spin it and let it settle naturally.  More than likely the sensor will be at the bottom since it's the heaviest part of the rim.  Add weights to approximate the weight of the sensor (see the manual for details).
You'll see in the picture how I used electrical tape to temporarily locate the tire weights while working through this part of the process.  This makes the job very easy, since you can remove all the weights and start over if things seem out of whack.  Later you can permanently affixing them to the rim.
With each change in weight, you'll need to repeat turning the tire slowly and letting naturally settle.  This does take time to do, but I find these types of jobs relaxing and less stressful than other things that might need fixing.
As you get closer to balancing the tire, the settling point will change and, as mentioned, the way the tire settles will change.  The best indicator is when the tire does NOT pendulum, but slowly comes to a stop at somewhat random locations.  At this point, the tire is sufficiently balanced for road use.
Depending on your rim, a filler extender might be needed to the business end of the sensor.  The TPChecker comes with one 90-degree extender to accommodate most setups.  Because of my rims, I needed to purchase an additional one online.  They are fairly inexpensive and can be found on Amazon or eBay.
Once the sensors and display are installed it's time to use the system.  Follow the instructions to setup it. Again, VERY easy and straight forward.
I commute daily to work about 45 minutes each way and have come to rely on having the tire temperature and pressure information readily available.  Luckily, I have NOT had a sudden loss of pressure in either tire, so I can't comment on the warning. However, I do use the information to fine-tune the optimum pressure setting for the type of ride I'm planning.  Hot days versus cold.  Wet versus dry.  Having the information available has allowed me to experiment with different tire pressures and better understand how my tires perform under different circumstances.  This used to be a bit of a guessing game.  Now, it's more of a science.
If it's not obvious, I really like the TPChecker.  It's simple, accurate, and sleek design makes it a perfect fit for knowing what the heck is going on inside the tire without looking like there's a computer hanging off the rails.  I recommend if you're considering a remote tire pressure/temperature setup – take a close look at what Gordon has to offer.
UPDATE:  Was on a ride through the West Virginia mountains near the end of the riding season and suddenly the display background turned red, indicating a loss in pressure below the set threshold.  Pulled over and found the 90 degree adapter I added to the tire had loosened slightly and was leaking air.  Did a quick topoff and tightening and off I went.
Cheers and Ride Safe!
Jersey
Jersey
robin
Nice write up was looking at the FOBO system for the same thing.
Do you live in Jersey or is that just your handle?
If so where?
Jersey
You're welcome and hope it helps in the decision-making.  Yep, born/raised in northern Jersey... Jersey City, East Brunswick, Hunterdon county.
Jersey
robin
Jersey
Ah!  Not far from Johnny's Hot Dog Stand. Best dogs and root beer ever!  Those frosted mugs are the best.
In southern Maryland, just south of Annapolis.
Jersey
TallRider
 I bought this last year from Direct Line parts on sale for 120 bucks.  No wires and no balance problems. Screws on tire stem. They recommend metal stems if you use the angle stems.  Works great. Comes on instantly when you move the bike. Only problem the ball bracket  that holds the display  the clamp cracked be carefully when tightening  it. May have been do to high heat we run in down here. Also showed tire temp.
https://m.summitracing.com/parts/scb-13-318?ibanner=MobileSwitchYes
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
Jersey
I checked that one out, but couldn't figure how it measured the temperature inside the tire.  Plus, it was easier to steal.  How's it working?
Jersey
F6Dave
I also bought the Show Chrome TireGard system.  HDL had them on sale and I bought the version with 4 senders for a bike/trailer.  I use them on 2 bikes, for little more than the price of the 2 sender set.
I got the one with the readout on a key fob.  It works great on my F6B with the ignition up by the gauges, but not as well on the old Valk.  You can carry it in your pocket and set it to vibrate when the tires exceed limits you set.
I'm very pleased to be able to check pressure and temperature so easily.  I also like the 2 minute installation with this design.
TallRider
Not sure about tire temp, my concern is always pressure. Crazy how much pressure changes riding. Rises as much as 6 pounds on hot days. Definitely a no Brainerd to install. Has a clock  and back lite as well.
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
BnB Tom
#9
Quote from: robin on Sat 31, Dec 2016, 06:03:07
If so where?
 FOBO was my choice.
Got em a few months ago.  10 minutes to install and setup.  Download app to my Iphone and instant and accurate readout! :cooldude:
  Work as described AND needed.  The only problem that I have is that I come thru the garage at home whether on the bike or in the car and I get notification by bluetooth as to the air pressure and temp. of front and rear tires every time unless I shut off the 'notifier'.
  Now you would think, why not?  Well.  My problem would be to remember to turn it back on.  :laugh:
 I guess instead of manually checking air pressure when I get ready to take the bike for a spin, THAT would be the time to turn it back on.  8)
Jersey
One thing I liked about the TP Checker is that the algorithm adjusts its warning thresholds for both temp and pressure... I seem to recall Boyle's Law on that topic.
When I wad shopping around and got this info, I couldn't assess if the other products did the same.
Jersey
