November 19, 2025, 10:33:59 AM
Valkyrie Odometer
Topic: Valkyrie Odometer (Read 869 times)
2ScooterS
Valkyrie Odometer
January 29, 2017, 07:59:22 AM »
Does anyone know of a company that can rebuild the odometer on my 1997 Valkyrie. Or a company that sell new speedometer ?
Valker
Wahoo!!!!
Texas Panhandle
Re: Valkyrie Odometer
January 29, 2017, 08:05:52 AM »
Are you SURE it needs rebuilt? If it's stopped working, chances are that it is the speedo drive at the wheel (forget this if the speedo still works), or the cable. I assume you have a standard or Tourer. Different system for an Interstate.
Last Edit: January 29, 2017, 11:12:24 AM by Valker
January 29, 2017, 09:02:48 AM »
Or find a used on on EBay.
January 29, 2017, 10:22:22 AM »
The machine screw holding the drive unit on loosens up it just LOOK'S right when really It ain't. Nuttin personal here but "we" as group generally say-check the easy stuff first.
RIDE SAFE.
saddlesore
January 29, 2017, 01:48:44 PM »
We need to know what the problem is.. I've had the cable break once and another time the tab that connects the gearbox to the speedometer broke off. The other problem I've had was the trip meter not working right.. I rotate several times and set at 9999 when I reset the trip meter.
DARE TO BE DIFFERENT
January 29, 2017, 03:58:48 PM »
Through Honda you may still be able to get one, they are not expensive.
DirtyDan
Kingman Arizona, from NJ
Reply #6 on:
January 29, 2017, 05:29:36 PM »
My first lasted till 138k a replacement was 400 if I recall
Dan
=> InZane XXV
