Dangit! FR signal was bad. Tab cracked off the housing; wouldn't hold the lens and I'd guess it corroded inside. Power was getting to the assembly, but no light. No sweat, changed the whole thing.
Well, a little sweat, because I had to remove the dang fairing on the IS. Ugh! Only good news was that I got through the whole thing without swearing (but I did have to use JB Weld to put the brass fittings back in).
All back together. Running light is on; turn on signal and it works. Turn it back off, and THE RUNNING LIGHT GOES OUT, TOO! Try the same thing on the left side and same thing occurs. I fiddle with the switch a bit and can get both running lights back on, but as soon as I use signal and cancel, same thing.
Bad switch?
