November 23, 2025, 10:38:14 PM *
Author Topic: Another valve stem clip bites the dust.  (Read 348 times)
MarcusS
New To Me August 2013
North Houston
« on: April 19, 2015, 10:39:44 AM »
shopping for a new front tire on line I saw the attached add. Note the valve stem clip is just hanging. My first valk front tire mount they threw mine away at a dealer not to be mentioned.
If you still use these things don't let a third party mess them up. Steel stems are cheap.
http://www.bobscycle.com/dunlop-elite-3-front-tire-150-80-17-sf150-17-radial.html
Life goes on whether you are in it for the ride or not.
« Reply #1 on: April 19, 2015, 10:53:05 AM »
I'm one that doesn't have much of a problem with OEM style stems and clips as long as they are  constantly looked at and maintained and the stems replaced with every tire change. I also hold the stem while checking and/or adding air.
I'm not one that would trust the dealer to replace them without adding a drop of paint or somehow mark the old stem beforehand.
I do have aftermarket steel/metal stems that will go on someday.
