« on: November 30, 2015, 11:48:26 AM » |
Had it up to 105 Saturday. Feels more powerful than my previous Standard. Maxed that one at 128 (gps) on a long straight road in N Dakota in 2005 One day maybe I'll be back in ND to wring this one out
« Reply #1 on: November 30, 2015, 12:41:26 PM » |
When was it built ? month and year.
« Reply #2 on: November 30, 2015, 12:47:45 PM » |
it's got a different trigger wheel, I/S carb springs and desmogged.
« Reply #3 on: November 30, 2015, 01:07:36 PM » |
it's got a different trigger wheel, I/S carb springs and desmogged. Doesn't answer my question.
« Reply #4 on: November 30, 2015, 02:35:15 PM » |
it's got a different trigger wheel, I/S carb springs and desmogged. It's a 98 dunno the month. Doesn't answer my question.
Detn8er
« Reply #5 on: November 30, 2015, 02:38:25 PM » |
it's got a different trigger wheel, I/S carb springs and desmogged. Find an Interstate ICM to put in it........remove the trigger wheel and replace with stock.....You'll be like holy shiznit this thing really goes zoom zoom...
Mr Whiskey
« Reply #6 on: November 30, 2015, 02:43:02 PM » |
'at right there's gonna "kill" your top end stroll, even with a 4* Bet she's flat to the boards by 115/118 or so. But she'll sure twist a-buck-an-a-nickle with a vicious quickness! Have fun
Peace, Whiskey.
« Reply #7 on: November 30, 2015, 03:08:08 PM » |
it's got a different trigger wheel, I/S carb springs and desmogged. It's a 98 dunno the month. Doesn't answer my question. Hmmmm, OK. Usually the month and year is on the data plate on the left side by the steering neck. It seemed as though I remembered it as being a '98. [ Mine is from 1/98] . I've been wondering if some early '98s have '97 engines. When I've had the valve covers off I never looked at the camshaft casting numbers, probably didn't know about the different numbers then. Now I'm too lazy to remove one just to look at it. The needles are also different in the 97s.
robin
Get on it and RIDE!!
Hardwick NJ
« Reply #8 on: November 30, 2015, 05:14:18 PM » |
it's got a different trigger wheel, I/S carb springs and desmogged. Find an Interstate ICM to put in it........remove the trigger wheel and replace with stock.....You'll be like holy shiznit this thing really goes zoom zoom...  I did that to my PUMPKIN what a difference
« Reply #9 on: November 30, 2015, 05:16:17 PM » |
'at right there's gonna "kill" your top end stroll, even with a 4* Bet she's flat to the boards by 115/118 or so. But she'll sure twist a-buck-an-a-nickle with a vicious quickness! Have fun  Really? It got to 105 lickety spit.
Mr Whiskey
« Reply #10 on: November 30, 2015, 06:48:17 PM » |
'at right there's gonna "kill" your top end stroll, even with a 4* Bet she's flat to the boards by 115/118 or so. But she'll sure twist a-buck-an-a-nickle with a vicious quickness! Have fun  Really? It got to 105 lickety spit. Like I said, "a-buck-an-a-nickle", quick  Above that she's over advancing the ign timing. (Biggest drawback to the Valky IMHO, mechanical advance.) We filed the key-way on the factory trigger wheel for my IS to give me right at 5* advance. (Some have reported cold start problems with the aftermarket trigger wheels, "teeth" on the wheel are too rounded.) She'd zoom to 105, by 110/112 you could feel it "flatten out", didn't wanna pull anymore. He77, I loved it! How often are you runnin' the ton+, as opposed to crackin' the throttle through all five gears? Cain't wait to see what mine will do after she looses all the weight  I 'spect she'll top out 'bout the same, but she ought to toss your head back gettin' there
Peace, Whiskey.
« Reply #11 on: December 01, 2015, 07:44:51 AM » |
Would a different trigger wheel cause an increase in RPM's in 5th gear?
« Reply #12 on: December 01, 2015, 08:12:57 AM » |
Maybe someone could come up with one, but, I'm not aware of one. I'm not a fan of the aftermarket triggers, tried them. Honda got this right. These engines do not like a lot of ignition advance. 27º is about it. Power drops off quick with more than that. The IS ICM has a different curve rate, but, total advance remains the same. So its the best of both worlds for a Std/tour.
« Reply #13 on: December 01, 2015, 08:18:46 AM » |
Maybe someone could come up with one, but, I'm not aware of one. I'm not a fan of the aftermarket triggers, tried them. Honda got this right. These engines do not like a lot of ignition advance. 27º is about it. Power drops off quick with more than that. The IS ICM has a different curve rate, but, total advance remains the same. So its the best of both worlds for a Std/tour. The reason that I asked is that my 2000 seems to turn 300 or so RPM's more than my 1999 at interstate speeds (70mph). And since the weather turned cooler it doesn't like to start very well in the mornings. The 99 will start easily in anything above 0 deg F.
« Reply #14 on: December 01, 2015, 08:21:33 AM » |
This 98 has no problem with cold starting.
« Reply #15 on: December 01, 2015, 08:38:34 AM » |
The difference in engine speed can be tire difference or error difference in tachs or maybe ICMs. Aftermarket triggers do tend to cause harder starting. The more initial/base advance the more these monsters don't want to start in the cold. Some folks say they have no issues with that, but, some do. I am in the 'do' category. Maybe someone could come up with one, but, I'm not aware of one. I'm not a fan of the aftermarket triggers, tried them. Honda got this right. These engines do not like a lot of ignition advance. 27º is about it. Power drops off quick with more than that. The IS ICM has a different curve rate, but, total advance remains the same. So its the best of both worlds for a Std/tour. The reason that I asked is that my 2000 seems to turn 300 or so RPM's more than my 1999 at interstate speeds (70mph). And since the weather turned cooler it doesn't like to start very well in the mornings. The 99 will start easily in anything above 0 deg F.
Jack B
« Reply #16 on: December 02, 2015, 09:27:17 AM » |
it's got a different trigger wheel, I/S carb springs and desmogged. Find an Interstate ICM to put in it........remove the trigger wheel and replace with stock.....You'll be like holy shiznit this thing really goes zoom zoom...  When I put the I/S ICM in my 98 Tourer you could feel it pull much harder. I still have a I/S ICM for sale.
Let’s RIDE
Pappy!
« Reply #17 on: December 02, 2015, 07:04:22 PM » |
Might be interested in that.......
jimmytee
« Reply #18 on: December 03, 2015, 02:18:14 AM » |
it's got a different trigger wheel, I/S carb springs and desmogged. It's a 98 dunno the month. Doesn't answer my question. Hmmmm, OK. Usually the month and year is on the data plate on the left side by the steering neck. It seemed as though I remembered it as being a '98. [ Mine is from 1/98] . I've been wondering if some early '98s have '97 engines. When I've had the valve covers off I never looked at the camshaft casting numbers, probably didn't know about the different numbers then. Now I'm too lazy to remove one just to look at it. The needles are also different in the 97s. I know that my 98 seemed to have more power than my 2000.
« Reply #19 on: December 13, 2015, 01:20:08 PM » |
115 today before I had to back off.  It was still pulling like a train.  Filled up after a short 117 mile zip about. 30mpg.
