November 22, 2025, 01:25:24 PM *
Author Topic: Installed Intersate ICM...wow!  (Read 871 times)
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« on: December 21, 2015, 05:22:43 PM »
This weekend I installed an I/S ICM and also a set of 11.5 Progressive 444's...
That I/S ICM is designed to get a much heavier bike motivating than my bobber project, I had already installed the I/S carb springs
...and that difference was amazing on my way to work this morning...might have been the crisp air but that thing was like a new bike...and looking good with the 444 shocks.
Will be chopping the frame stubbies as soon as I get my turn signal relocation brackets
« Last Edit: December 21, 2015, 05:37:04 PM by RDKLL » Logged
Jack B
Two Rivers Wis
« Reply #1 on: December 22, 2015, 05:32:59 AM »
Good to heard the I.S. ICM made a different.
Good luck with the bobber project?
Let’s RIDE
SpidyJ
Murrells Inlet
« Reply #2 on: December 22, 2015, 05:41:54 AM »
Sick machine.......I love it!
1999 Fast Black Interstate
Peace,
johnnywebb
jdp
« Reply #3 on: December 22, 2015, 07:40:40 AM »
Nice looking bike, hope your butt doesn't hit that tire, very nice bike
Momz
ABATE, AMA, & MRF rep.
« Reply #4 on: December 22, 2015, 01:55:22 PM »
I tought my 97 Bobber Valk was fast.
BUT NOOOOO,.........!!!!      It became REAL FAST when I put in the I/S carb springs and an I/S ICM.
But seriously, it only accelerates a bit harder and no real HP gain.  (It may only feel quicker at idle to about 4500 RPM though)
ALWAYS QUESTION AUTHORITY!
RDKLL
Mesa, AZ
« Reply #5 on: December 22, 2015, 04:34:44 PM »
Momz,
that is exactly right...also cold starts seem to be easier. It starts and idles and then stays running with just a little gas and it stays running and..,
That midrange....man!
Would 38 slow jets also play into the midrange improvement
TOPGUN
Valkyrie - Dark Side
Cleveland, OH
« Reply #6 on: December 22, 2015, 04:52:22 PM »
http://vrcc.photostash.com/vrcc_20861/Both%20Valk%20Bikes%200713%20013.JPG
http://vrcc.photostash.com/vrcc_20861/Both%20Valk%20Bikes%200713%20018.JPG
http://vrcc.photostash.com/vrcc_20861/Both%20Valk%20Bikes%200713%20020.JPG
Thought I would try and post these pics if you need any ideas. I made a couple of these and it's a great feeling when they are done. Runs like a bat outta...TOPGUN
TOPGUN
Momz
« Reply #7 on: December 23, 2015, 06:58:29 AM »
Momz,
RDKLL,
Swapping to .38 slow jets wil NOT improve your torque/power/acceleration, but it will make your fuel mileage worse. If you store your bike for long periods and do not properly drain the float bowels,.....then the .38 jets may slow the CLOGGING due to the fact that the internal diameter is larger.
I'd stick with the .35 jets and run Berrymans B12 Chemtool once in awhile and drain the float bowels before storge.
Hope this helps and MERRY CHRISTMAS!!!
RDKLL
Mesa, AZ
« Reply #8 on: December 26, 2015, 09:06:29 AM »
The 38's went in when I had to take the carbs out to clean them and living in the NE. Now I find myself in Arizona...would it be worth the hassle to go back to the 35's?
Punisher
No, not vengenance. Punishment.
« Reply #9 on: December 26, 2015, 04:03:05 PM »
I wouldn't if it's running as good as you say and you are satisfied with its performance and fuel mileage.
RDKLL
Mesa, AZ
« Reply #10 on: December 27, 2015, 04:21:58 AM »
Cool, because I dont want to do that again...although it would be much easier than the first time...
Otus
Scott
Taylor Mi.
« Reply #11 on: December 27, 2015, 05:13:47 AM »
You can change the Jets with the carbs on the bike.
