November 22, 2025, 07:14:11 AM *
Author Topic: What handle bar phone mount do you use?  (Read 697 times)
« on: January 17, 2016, 07:51:57 PM »
I am considering some longer rides and want to be able to put my I phone 6 on the handle bars. Two reasons video recording, directions and phone calls. What mounts to you guys use and are you happy with them?
Jopson
Egan SD
« Reply #1 on: January 17, 2016, 10:46:37 PM »
This is what I'm using, mounted it right on the handlebar riser clamp using a home made bracket, so far so good.
I like it because rather than the spring loaded clamps, you can screw the thumbscrews in and your phone isn't coming out again til you unscrew them.
http://www.jpcycles.com/product/605-849?utm_source=none&utm_term=&cid=Google+SEARCH+NON-BRAND+Google+Shopping+Campaigns+-+Manufacturer+Terms+-+On+Sale&adpos=1o2&creative=67615001290&device=m&matchtype=&network=g&gclid=CNDvjPvmssoCFQqtaQodsigP5Q
mark81
Cincinnati Ohio
« Reply #2 on: January 17, 2016, 10:59:02 PM »
I have a galaxy note 4 with the defender series otterbox. a few zip ties through the belt clip around the center of my bars on my interstate and its solid as anything. it is also the only thing I could find that was large enough to hold my phone. no way of shooting video with it but for gps I love the location
1997 Honda Valkyrie
1981 Honda CB750 Custom
wiggydotcom
Yorkville, Illinois
« Reply #3 on: January 17, 2016, 11:23:36 PM »
I've used RAM mounts on my bikes for a long time. The same mounting system can be used for my GPS or Phone with just a changeout of the holder. On my current bike I have a setup that allows for both devices to be used at once as I have a double ball setup.
http://www.rammount.com/part/RAM-B-149Z-UN10U
« Last Edit: January 18, 2016, 06:56:12 AM by wiggydotcom » Logged
VRCC #10177
VRCCDS #239
Dennis from Blythe
Blythe, Ca
« Reply #4 on: January 17, 2016, 11:37:32 PM »
I have the Note 4 and the defender otterbox too.  I have the normal size spring loaded X-grip holder.
What I had to do to make the phone fit was, the two arms you squeeze to open the holder, I re-bent them. I bent those 2 arms strait than  bent them up again to  make the grippers, slightly wider.
Now the X-grip works just fine.
mark81
Cincinnati Ohio
« Reply #5 on: January 18, 2016, 12:23:46 AM »
Good to know something else can be made to work for this but I don't think anything will be as secure as the otterbox holster. low budget too works for me. my brother spent around $75 on his phone mount + charger and audio cables. for that price I'd rather get lost and put the money in my gas tank
1997 Honda Valkyrie
Lyonardo
« Reply #6 on: January 18, 2016, 12:49:52 AM »
I use the Ultimate Addons system.
It's completely watertight, it rotates, and it recharges my phone with a cable system that connects to the battery..
Plus, it has various cable tips that can be switched out depending on what device I take with me.
you can even swap out the case whenever you update your phone.
http://www.amazon.com/gp/product/B01633SP1I?keywords=ultimate%20addons%20iphone%206&qid=1453108186&ref_=sr_1_8&sr=8-8
« Reply #7 on: January 18, 2016, 06:49:22 AM »
Hey Robert, my method is really hi-tech.......either my shirt pocket or the saddlebag.  Grin
Just yanking that leg a bit, but I simply don't concern myself with the phone while riding. I have a GPS mount for a GPS I've used once in seven years. Usually the phone is in the saddlebag because I like to carry my small digital camera in my shirt or jacket pocket. Plus, my tank bib has a pocket in it for quick access.....usually for my sunglasses or toll pass.  cooldude
TallRider
Cape Coral, Fla
« Reply #8 on: January 18, 2016, 07:12:35 AM »
Robert I think I showed you this at the Pizza gathering at Jerry's place.
I used Ram mounted to crossbar on Honda windshield
USB and Power outlet
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
davit
Deerfield, WI
« Reply #9 on: January 18, 2016, 07:53:04 AM »
I also use the X Grip on the bars, used it with my phone to navigate a 5,000 mile trip last September.  The phone will work itself loose on rough roads but a stop at Dollar General to pick up some hair bands was a quick solution.
« Last Edit: January 18, 2016, 09:22:59 AM by davit » Logged
Pappy!
Central Florida - Eustis
« Reply #10 on: January 18, 2016, 03:04:31 PM »
I also use the RAM X-grip.
Have not had a problem with retention on my iPhone6 but Lesa has had an issue with her larger mount and her iPhone6+ coming loose. She has literally caught it twice now. We just put a ring on the back of her phone case that I can use to secure it better.
Like the idea of those hair bands as well !
DarkSideR
Pueblo, Colorado
« Reply #11 on: January 18, 2016, 04:10:20 PM »
I have the Akron. It mounts find to the handlebars, it's water resistant but not fully water proof (does the job if the rain though). Mine has served me well for 2 years now.
http://www.shopandroid.com/arkon-water-resistant-bike-mount-and-case-for-55-smartphones/3A102A17318.htm?utm_source=GoogleProducts&utm_medium=shopping_engine&utm_campaign=store&gclid=CjwKEAiAt_K0BRCzjtv92_HGoR0SJAA9QNn_fgagCdNyiH39_gABY-73rFEI4u9IymNDTE_8zaD5XxoCaq3w_wcB
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
