November 22, 2025, 08:23:32 AM *
Author Topic: DIY Murphy bed  (Read 902 times)
Roidfingers
Tuscaloosa, Alabama
« on: January 19, 2016, 01:46:53 PM »
So I have a spare room that is only used, maybe once or twice a year. I thought hey ! Why not buy a Murphy bed and that way I can free up the room to put my treadmill and Total gym in.
Well I got to looking online for murphy beds and was shocked. 1500.00 ??? dang. Then I thought well what about just the hinge assemblies? 360.00 ??? Ouch.
So without any plans and just the mattress dimensions, here's what I built with just a lot of forward thinking.
I still have to sheave the sides and install a hinged piece of trim at the top. Also gonna cover the hinges at bottom with same trim.
The feet underneath are hinged and will stow in the space at head of bed when not in use.
Total cost...... Bout 150.00
Any extra thoughts would be greatly appreciated.
« Reply #1 on: January 19, 2016, 01:50:30 PM »
Looks well made  cooldude cooldude
JimmyG
« Reply #2 on: January 19, 2016, 01:56:34 PM »
I'd love to see your drawings or plans that you finalized on this. I am planning on the same thing and love looking at ideas for these. cooldude
The trick seems to be to have it assisted to raise it up and secure it.   You Might make part of the leg system hinged as well to be part of the cover trim for the bottom. As the bed lowers, the legs swing in position to support bed.  There are some neat ideas floating around, but for simplicity, I like your beginnings.  cooldude
« Last Edit: January 19, 2016, 02:02:19 PM by JimmyG » Logged
Roidfingers
Tuscaloosa, Alabama
« Reply #3 on: January 19, 2016, 01:56:46 PM »
Everything is screwed and glued. I never use nails on any project if I can use a screw. Cant decide if I want to stain or paint though.
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: January 19, 2016, 01:59:01 PM »
JimmyG, I had no plans. Just went with the dimensions of the quenn mattress. 60 x 80 and did some ( a lot ) of forward thinking. I would be glad to help you in anyway I can.
JimmyG
« Reply #5 on: January 19, 2016, 02:04:54 PM »
I understand, I build a lot and never have plans, just like you, forward thinking. Often, I put her in reverse and begin again, LOL.  My idea is similar to yours, but using a hinged leg system.
Roidfingers
Tuscaloosa, Alabama
« Reply #6 on: January 19, 2016, 02:17:31 PM »
I also thought about the hinged leg system. But in order to do that you would have to use at least a 7/8 plywood for support. Mines 15/32 to be exact. The weight of the 7/8 plywood and mattress would need two people to lift. Unless u pay the 350 for the helper springs.
Also you have to take in account for the mattress thickness. Mines 8 inch memory foam. You will need a gap at the top, as in picture, to allow it to pass through the opening. That's where I will have a similar piece of trim hinged to cover the gap but allow me to put bed up. Then lock in place.
PAVALKER
Pittsburgh, Pa
« Reply #7 on: January 19, 2016, 02:20:47 PM »
Speaking of legs......I don't see them in the bottom photo, but see some 2x used as such on the down position.  Where do they go or attach when up?
« Last Edit: January 19, 2016, 02:22:23 PM by PAVALKER » Logged
John
Roidfingers
Tuscaloosa, Alabama
« Reply #8 on: January 19, 2016, 02:32:30 PM »
PA VAlker,  2 x 8 1/2 . Level with front of bed. They are separate but also hinged to be stowed in the area behind the head of the bed. I lift it up slightly. pull out footings. place bed on floor. stow  them and then raise the bed. Makes it so sturdy I can dance on it when down.
samoanrich
Western PA
« Reply #9 on: January 19, 2016, 03:43:53 PM »
What's your ceiling height? Daughter and I are in the planning stages of building one for her. Older home, with low ceilings upstairs, not sure we have the height.
U.S Army 1972-1976, PGR
« Reply #10 on: January 19, 2016, 03:55:10 PM »
      IF your ceiling is too low for the length go from the width.  cooldude Just one of dose random thoughts.  coolsmiley RIDE SAFE.
Roidfingers
Tuscaloosa, Alabama
« Reply #11 on: January 19, 2016, 04:02:54 PM »
sam, its 8 ft. But like said. U can do it horizontily
Roidfingers
Tuscaloosa, Alabama
« Reply #12 on: January 19, 2016, 04:11:54 PM »
I've also thought about a trunk type system where the platform is hinged. have a memory foam mattress then fold up and lock the trunk shut. would need more floor space but no ceiling space.
« Reply #13 on: January 19, 2016, 04:51:46 PM »
It's great to free up room space.  But obviously, if you put furniture where the bed comes down, it will still have to be moved before using the bed.
But I still like the idea and your craftsmanship.  I didn't flunk Shop class 1, but I was informed I had probably reached my potential and should not bother with Shop class 2.  It's kind of funny, because they told me the exact same thing about Typing class 2.
I also have a spare bedroom (mostly storage/unfurnished), and also need a spare bed once or twice a year.
My king bed is one box spring and two mattresses (the first was too hard, but still new, so I removed the frame when adding the 2d mattress so I didn't have to use a ladder to get in and out).  When it's time for a guest, I just yank the extra king mattress off my bed and drag it across the hall.
Jersey mike
Brick,NJ
« Reply #14 on: January 19, 2016, 05:16:26 PM »
Murphy beds make me think of this, probably the best ever.
https://m.youtube.com/watch?v=bQZ-xQ329lA
cokebottle10
Green and Silver 99 I/S
Fletcher NC
« Reply #15 on: January 20, 2016, 05:30:33 AM »
You could use a hinge torsion spring like on a triler ramp to help lift the bed.
Thanks, David in Fletcher NC
Roidfingers
Tuscaloosa, Alabama
« Reply #16 on: January 20, 2016, 09:59:49 AM »
Just trying to keep it simple. But yes you could. just have to make room for it when u build it.
Disco
Republic of Texas
« Reply #17 on: January 20, 2016, 11:21:28 AM »
Great job, RF!  Especially the budget part.   cooldude
I recently did some shopping for Murphy beds and was quickly shocked at how much they can cost.
So, I ricocheted off to shopping for just the hardware.  Same story.   Shocked
http://www.murphybeds.com/shopHardware
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Roidfingers
Tuscaloosa, Alabama
« Reply #18 on: January 20, 2016, 02:40:50 PM »
EXACTLY  !!!!!!!!!!! lol
« Reply #19 on: January 20, 2016, 04:09:05 PM »
I'm always interested in history, so I looked it up.
http://mentalfloss.com/article/30266/who-was-murphy-and-why-there-bed-named-after-him
Jersey mike
Brick,NJ
« Reply #20 on: January 20, 2016, 07:23:27 PM »
If you cannot come up with a hidden mechanical way to lower and raise the bed, what about a exterior mounted rope and pulley. Once the bed is lowered, the rope can be moved aside and stored and when it's time to raise the bed, reattached and then stored aside. It may not be the concealed but it may help and be better than squatting and lifting.
Roidfingers
Tuscaloosa, Alabama
« Reply #21 on: January 20, 2016, 07:38:49 PM »
Actually, I have no trouble at all. And its only gonna be used once or twice a year anyway.
Jess Tolbirt
White Bluff, Tn.
« Reply #22 on: January 21, 2016, 05:10:22 AM »
whoever comes over to visit can lower and raise the bed for you
