November 21, 2025, 10:07:48 PM *
Author Topic: Computer guys I need help  (Read 978 times)
« on: March 03, 2016, 01:37:05 PM »
I don't use the touch pad on my HP laptop. I use a mouse.
If I touch it the font size and correspondingly the page size will increase or decrease.
I've found out how to disable the touch pad BUT every time I restart the laptop I have to go thru the same disable process.
Is there a way to PERMANENTLY disable the bloody touch pad.
« Reply #1 on: March 03, 2016, 01:41:20 PM »
There might be an option in the BIOS or system setup to disabled it. Reboot the computer and on the first splash screen (BEFORE Windows starts loading) look for something like "Press F2 to enter setup" or F10, or something, do that, and poke around looking in there.
Disclaimer - Don't change anything in the BIOS settings you're not sure about or "Bad Things" can happen.
« Reply #2 on: March 03, 2016, 01:43:30 PM »
Another option, assuming this is Windows, is to go into the "Device Manager" and disable to hardware for the touchpad through there.
« Reply #3 on: March 03, 2016, 01:47:00 PM »
That's what I have already done a few times.  Grrr.
Black Pearl's Captain
Emerald Coast
« Reply #4 on: March 03, 2016, 02:23:35 PM »
Is it the mouse scroll wheel or moving the mouse? CTRL key and scroll at the same time will change what you describe. If so look for a stuck ctrl key.
« Reply #5 on: March 03, 2016, 04:24:25 PM »
Look in your control panel and/or application listing for something about "Synaptics Touch Pad" or something like that. You should be able to at least disabled the multi finger gesturing (I.E. The zooming crap) and such with that app... hopefully... maybe...
TallRider
Cape Coral, Fla
« Reply #6 on: March 03, 2016, 05:04:17 PM »
My laptop has a button at the top center of the pad. This disables the touchpad turns it on and off. It is imbedded in the frame of the pad and if you don't know what it is would mistake it as just part of the frame. Check your pad closely. My laptop is an HP. Some times you can't see the forest for the trees cooldude
1951 HD FLH Chopped
1978 Honda Goldwing
2005 VTX 1800
2014 Honda Valkyrie
« Reply #7 on: March 03, 2016, 05:06:42 PM »
I don't have one of those. Thanks.
Mebbe an icepick driven downwards vertically with some force would work?  Shocked
« Reply #8 on: March 03, 2016, 05:08:14 PM »
Nope it's the touch pad.
If I accidentally stroke it whilst typing the font/page size decrease/increases.
hukmut
Stone County, Mississippi
« Reply #9 on: March 03, 2016, 05:15:53 PM »
Take it to a guy who will load a form of Linux and forget about Windows. And viruses. It will do ANYTHING that Windows will do without all the Windows quirks. Even makes your old computer faster.
Ride safe...
« Reply #10 on: March 03, 2016, 05:17:17 PM »
What's the model number, I'll do some searching and see if I can find anything specific?
And I'm assuming it's got Windows, but what version?
DirtyDan
Kingman Arizona, from NJ
« Reply #11 on: March 03, 2016, 07:27:05 PM »
"Mebbe an icepick driven downwards vertically with some force would work?"
I WAS going to be wisenheimer but restrained myself, glad you beat me to it
dan
Dorkman
San Carlos, CA
« Reply #12 on: March 03, 2016, 10:33:28 PM »
From your friendly Google:
HP laptops are equipped with Synaptics touchpad drivers, which allow you to enable, disable and customize various touchpad settings. Click the Windows "Start" button and type "mouse" in the Search field. Click "Mouse" to open the Mouse Properties window. Click the "Device Settings" tab and click "Enable" or "Disable."
« Reply #13 on: March 04, 2016, 04:44:06 AM »
Yep I've done that but the pad comes alive every time the laptop is turned on. It's not a permanent disable.
I can understand why so if you forget a mouse or it breaks you can still use the laptop.
« Reply #14 on: March 04, 2016, 04:51:55 AM »
Windows 10
HP 15-F305DX
« Reply #15 on: March 04, 2016, 06:23:07 AM »
Windows 10
HP 15-F305DX
Haven't been able to find exactly what the BIOS setup looks like, but to get to it, power on and immediately start hitting the ESC key until the screen changes to a "Startup Menu", things like F1 System Information, F2 System Diagnostics, etc...
We want F10 BIOS Setup
Look around in there for anything about disabling the built in touchpad. But as I said earlier, be very careful, don't make any OTHER changes in here, it could do Bad Things.
I searched as much as I could and wasn't able to see that setting in the BIOS for this system, but since I don't have one actually in front of me it's worth a look see to double check if the option is there or not.
And if none of that works, and you REALLY want it gone, you could follow this guy's video guide for opening one up (The guide is actually to replace the hard drive, but it'll guide you into the guts) and find the ribbon cable(s) going to the touchpad and simply unplug it.
https://www.youtube.com/watch?v=WyjRAxmpYQQ
« Reply #16 on: March 04, 2016, 07:32:52 AM »
Is this any different from what you tried already?
Re: How can I turn off my touchpad on my new HP laptop computer [ Edited ]
Options
‎09-03-2014 08:06 PM - edited ‎11-11-2014 08:16 AM
I had the same problem and hated losing my info while typing.  Well after 9 months I have finally found how to disable.  Hope this helps you......Go to your control panel,  click on Hardware and Sound.   Once there, under Device and Printers, click on Mouse.  A small box (Mouse Properties) will open up.  Click on the "ClickPad Settings Tab". Once there you will click on "ClickPad Disable".  A small box will open up letting you know that you are about to disable the only active Synaptics pointing device, just click OK. You will then want to click apply, then OK.  Voila!  That should take care of it.  If you ever need to enable it just follow the above steps and enable the clickpad.  For some reason HP has called the Touchpad, "ClickPad.
t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« Reply #17 on: March 04, 2016, 07:41:30 AM »
Put duct tape over it and your done!!  Wink
Cliff
Manchester, NH
« Reply #18 on: March 04, 2016, 10:47:19 AM »
agreed!!!!
VRCC # 29680
« Reply #19 on: March 04, 2016, 12:08:31 PM »
Sometimes simple is best  cooldude Grin
I have some kinda matt black.
Titan
BikeLess
Lexington, SC
« Reply #20 on: March 04, 2016, 01:57:35 PM »
Here's a link to a message thread which may help you with the issue. There were a number of message where the issue was discussed, but not solved. I pasted the one message here that supposedly did take care of it. Hope it helps. If not, I have nothing.
http://h30434.www3.hp.com/t5/Notebook-Hardware-and-Upgrade-Questions/How-to-disable-multi-touch-zoom-on-touchpad/td-p/2201069/page/3
I had the problem of the pinch zoom feature automatically defaulting back to active, no matter how many times I unchecked the box. I called HP and they fixed it.
*you MAY have to use a mouse via USB cord after uninstalling the touchpad.
1. Go to settings, devices, mouse & touchpad, additional mouse options, device settings, settings, and uncheck the boxes for pinch zoom in control panel. I unchecked multifinger gestures all together.
2. Uninstall the Synaptics TouchPad driver. Go to settings, connected devices, device manager, mice and other. Right click to uninstall.
3. Restart computer after uninstalling
4. Open HP Recovery Manager
5. Click re-install drivers
6. Scroll to find Synaptics TouchPad driver
7. Install program
8. Restart computer
9. Go uncheck the boxes again from step 1.
10. It should stay unchecked from now on.
« Reply #21 on: March 06, 2016, 01:55:05 PM »
7. Install program
8. Restart computer
Thanks. I'm using a wireless mouse so I'm hesitant to do this.
I'm going to get everything set the way I like the various web pages I use the most to look. Then I'm going low tech with the duct tape.   Grin
