November 20, 2025, 10:25:02 PM *
Author Topic: 1997 Valkyrie - No power to Right side  (Read 741 times)
Bookemdnno
Bethlehem, PA
« on: July 29, 2016, 08:45:44 AM »
Please Help - I have a 97 Valkyrie. I just did oil change, and new plugs.  Rode it a few times, bike ran awesome!  Started it the other day, rode about a block, and all of a sudden no power to right side. (No sounds from pipes) [I have Cobra 6 into 6] I made it home under extremely low power, and a few stalls, and I checked plugs, and all seem fine. No fouling.  What would cause a loss to 1 side completely?  I'm at a complete loss as to how to look at this, and the dealer will Certainly bend me over for probably a simple cure.  Any help would be greatly appreciated.  Thanks!!!
« Reply #1 on: July 29, 2016, 10:05:15 AM »
plug wires good?
Disco
Republic of Texas
« Reply #2 on: July 29, 2016, 10:57:44 AM »
As silly as it sounds, my money is on fuel delivery.
OEM petcock?  If so, when was the last time you replaced the cover set (diaphragm, etc) and checked the vacuum line?
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Wizzard
Bald River Falls
Valparaiso IN
« Reply #3 on: July 29, 2016, 10:58:24 AM »
you just got a left handed Valk. Simple   Roll Eyes
VRCC # 24157
« Reply #4 on: July 29, 2016, 11:00:35 AM »
How much gas in the tank?
Jess Tolbirt
White Bluff, Tn.
« Reply #5 on: July 29, 2016, 12:23:23 PM »
fuel line feeding the right bank plugged up...
« Reply #6 on: July 29, 2016, 01:12:09 PM »
I too think I'd look at the fuel fuel supply right after a compression test just for peace of mind.
Bookemdnno
Bethlehem, PA
« Reply #7 on: July 29, 2016, 02:27:25 PM »
Thank you all. I appreciate all your ideas. I will update when I find it. Thanks again!
indybobm
Franklin, Indiana VRCC # 5258
« Reply #8 on: July 29, 2016, 02:33:09 PM »
First thing to do is let people know where you are. That way maybe someone can give you a hand.
With the engine not running and cooled off, have you opened the carb drains one at a time for the right side to see if they have gas in them?
So many roads, so little time
VRCC # 5258
CajunRider
Broussard, LA
« Reply #9 on: July 29, 2016, 03:54:06 PM »
At first I thought coils... but those run 1 coil to opposing cylinders.  So, only losing one side can't be coils.
I'd have to think fuel (as others have already said).
When you checked the plugs, were they wet?  Running on 3 cylinders for any amount of time would put enough fuel in there to at least make it noticeably moist.
Sent from my Apple IIe
cokebottle10
Green and Silver 99 I/S
Fletcher NC
« Reply #10 on: July 29, 2016, 04:18:03 PM »
Did you wash it or get it wet? Check the weep holes for the plugs. Mud dobbers can plug them up and short them out.
David in Fletcher NC
Bookemdnno
Bethlehem, PA
« Reply #11 on: July 29, 2016, 04:40:22 PM »
I Did wash the bike at the end of the previous day. Then, the next morning is when it happened.  How do I check this for the reason?
Bookemdnno
Bethlehem, PA
« Reply #12 on: July 29, 2016, 04:45:41 PM »
Sorry, new to forums. I'm not sure how to reply to a single reply, so I'm just updating at the end of all of the replies: I live in Bethlehem, PA to answer another message.  I have not deep dived into the bike yet, as I am not with the bike until Sunday. I was just trying to get somewhere to start to dig in once I get home.  Thank you again to all.  I at least can research these potential issues, and try and get the bike going again.  If anyone is on the Bethlehem, PA area, by all means feel free to let me know and I will definitely be open for help.  (Paid of course) Thanks!!
« Reply #13 on: July 29, 2016, 05:07:44 PM »
pull your spark plug boots. There are drain holes down in there that could get clogged. Doesn't seem like all three would be clogging at the same time, but maybe. Being that you said you checked the plugs and they were not fouled, I'm betting on a fuel problem.
Karen
Boston MA
« Reply #14 on: July 29, 2016, 06:11:34 PM »
If you have a leaf blower, try running it all over the bike; when I take my Valk to the car wash, it develops electrical gremlins that can take a while to correct themselves. Just a thought, I could be just all wet...  Shocked
« Reply #15 on: July 29, 2016, 06:53:46 PM »
How many miles are on this bike?
Has anything been done internally?
Has the timing belt been changed.
What fuel are you using?
How's the throttle feel?
I'm sure there's a million other questions that could be asked.
You came to the right place to ask questions, I'm no expert but, there are some here.   Give them some clues.
« Last Edit: July 30, 2016, 07:34:31 AM by Rams » Logged
« Reply #16 on: July 29, 2016, 07:34:08 PM »
Also you might want to post this on the tech board. Lots of them guys don't associate on this side of the tracks.  cooldude
Mr Whiskey
« Reply #17 on: July 29, 2016, 11:23:03 PM »
Whole bank dead all at once.
First thought, broke timing belt.
I really hope that's not it Bro.
These are interference engines.
Peace, Whiskey.
« Reply #18 on: July 30, 2016, 05:17:43 AM »
Thats why I recommended a compression test, just in case.
Also the points about checking the drain holes and opening the carburetor drains checking for fuel flow are good ideas.
« Last Edit: July 30, 2016, 05:26:07 AM by Patrick » Logged
« Reply #19 on: July 30, 2016, 07:36:52 AM »
That was my fear also but, not being an expert, I didn't want to suggest it.
Possibly a broken cam?   Is it possible for the cam pulley to spin while not turning the cam shaft?   Stranger things have happened.
« Last Edit: July 30, 2016, 09:48:36 AM by Rams » Logged
NEHI
« Reply #20 on: July 30, 2016, 07:53:26 AM »
     My I/S did the same thing on the left side. It ended up being a broken camshaft. Good thing was it didn't bend any valves, bad thing it left me stranded just north of Las Vegas (I live in South Florida).
Bookemdnno
Bethlehem, PA
« Reply #21 on: August 07, 2016, 04:25:28 PM »
Thanks for all the possibles.  I found it to be the petcock.  I will be replacing it.  Thanks again!!!
Disco
Republic of Texas
« Reply #22 on: August 07, 2016, 06:23:22 PM »
Cover set + screen set and you're good to go.  Glad you got off easy.   coolsmiley
While you're in there, check all the vacuum lines and boots from air box to carbs and from carbs to intakes.
78 CB550K
