November 19, 2025, 07:08:36 AM *
Author Topic: Who knows what these cartridge's are?  (Read 882 times)
gregk
Retired
Chippewa Falls, wi.
« on: February 23, 2017, 07:35:30 PM »
I have 2  similar with different markings.looks like a micro 30-30 case fired, 1 1/2 " long, neck dia. Sim. As a 30 cal. . 1 is marked 35 then little space and then a 1, opposite of these its marked 16. Looks like copper case.  Other case say #2  is stamped 71 and on the opposite side marked 16, the case I'm guessing is tin coated dark brown paint. I can tell they came from some kind of auto.
« Reply #1 on: February 23, 2017, 07:47:33 PM »
Total shot in the dark (Pics would help) but 7.62 Tokarev by chance?
gregk
Retired
Chippewa Falls, wi.
« Reply #2 on: February 23, 2017, 07:58:11 PM »
I don't ave a clue, but the case looks similar to your pic. Seek. I haven't learned to do pics. yet but I can email someone a pic..
RP#62
Gilbert, AZ
« Reply #3 on: February 24, 2017, 10:56:47 AM »
357 Sig and 400 Corbon also come to mind, but those cases are less than an inch long.
-RP
gregk
Retired
Chippewa Falls, wi.
« Reply #4 on: February 24, 2017, 02:34:00 PM »
Serk, I hope you see this because I'll delete this tomarrow. You were right 7.62x39. I stopped at a place today that likes to sell assault type stuff. The case that looks like copper is brass. Thanks
« Reply #5 on: February 24, 2017, 02:39:10 PM »
The other hint you get from that shell is the polymer (clear) coating; most of that stuff is Eastern Block/Russian/Chinese in origin (or what used to be Eastern Block).
« Reply #6 on: February 24, 2017, 10:09:24 PM »
I was thinking for the Broomhandle. 9mm mauser?
As for pictures.
http://www.valkyrieforum.com/bbs/index.php/topic,85788.0.html
« Reply #7 on: February 25, 2017, 06:23:42 AM »
Ah, cool. I was close but a bit off. 7.62x39 is a low powered rifle round, 7.62 Tokarev is a pistol round, but both from the Eastern Bloc...
7.62x39 is the cartridge most SKS and AK47s fire.
7.62x39 on the left, 7.62 Tokarev on the right:
And as Jess says, that coating is common of com bloc ammo.
« Reply #8 on: February 25, 2017, 06:27:04 AM »
Think you mean 7.62X25. 7.62X39 is the round used in AK's
Serk beat me  cooldude
