August 17, 2025, 01:06:52 AM *
Author Topic: Rostra cruise control  (Read 2348 times)
RUDE DOG - Steelers
New Jersey - VRCC # 3966
« on: July 19, 2020, 06:53:51 AM »
Thinking of buying the Rostra cruiser for my Interstate. Is this the one I should get?
https://www.ebay.com/itm/250-1223-ROSTRA-UNIVERSAL-ELECTRONIC-CRUISE-CONTROL-KIT-NEW-/222919027884
Are there any other add ons I need for it? Will have my mechanic install it, hes an expert with wiring. Curious how many hours in general it would take to install?
txtriathlete
« Reply #1 on: July 19, 2020, 08:43:29 AM »
You can check Murphs - https://www.murphskits.com/product_info.php?cPath=25&products_id=369&osCsid=t7fad-Oq9zjm1OXccxIxk3
Their listed price is higher but they include the handlebar mounted controller, the ebay kit does not.
Murphs also offers a handlebar mounting bracket, which you will either need to buy or make to mount the controller.
I made my bracket for my CCS-100 Audiovox controller from a small piece of sheet metal, and located it on the brake mount on the right side. The IS left handgrip has a lot of radio controls that get in the way.
My CCS took a few hours to set up, mainly due to vacuum line plumbing which the Rostra does not use.
h13man
Indiana NW Central Flatlands
« Reply #2 on: July 19, 2020, 09:23:42 AM »
I'd suggest using  https://brakeawayproducts.com/product/7cp01-metric-and-victory-cruisers/as they are easier to install and VERY reliable. Note not compatible with Interstate model.
« Last Edit: July 19, 2020, 09:26:04 AM by h13man » Logged
« Reply #3 on: July 19, 2020, 11:01:50 AM »
A throttle lock with a throttle rest work well together.
The rest you can set on the fly, which allows you to loosen/release your grip on the throttle. The lock allows you to remove your hand from the grip.
The lock works well on flat country, it holds a steady throttle position.
But I got spoiled riding the GW with the CC, it works off the speed, so hills/mountains aren't a problem. Love to be able to set my speed on a 2 lane Hwy and let people just pass me.
I bought the CCS-100, and am still in the process of installing it on my IS. 2 hours to just get out of town to the mountains where the winding roads start, make it a nice addition to the bike. I posted in my build thread, made a air reservoir fed from 2 vacuum lines.
« Last Edit: July 19, 2020, 11:09:53 AM by gordonv » Logged
RUDE DOG - Steelers
« Reply #4 on: July 19, 2020, 06:15:57 PM »
I has the Break away and it worked good but it had to be modified to work. Wanted to try the electronic.
Jersey
VRCC #37540
Southern Maryland
« Reply #5 on: July 20, 2020, 07:38:57 AM »
A lot of us have had great success with the Rostra.  Also their customer service is very good.  If you have an I/S then the electronic motor can be mounted behind the dash.  For the the others it can be placed under the seat, etc.
Jersey
RUDE DOG - Steelers
« Reply #6 on: July 20, 2020, 10:21:51 AM »
How long of an install is it for someone experienced?
Jersey
VRCC #37540
Southern Maryland
« Reply #7 on: July 20, 2020, 12:37:02 PM »
I'd say it's one of those long half-day projects... probably a full day though if you want to be neat and clean on everything.
Recommend fully planning each of the main things you'll need to do before starting:
  • Mounting cruise motor
  • Electrical connections and Relays
  • fishing cable & support connection near throttle
  • connecting cable to throttle
  • Fishing control line and mounting handlebar controls
  • Testing and Configuration
Hope that helps,
Jersey
Jersey
RUDE DOG - Steelers
« Reply #8 on: July 20, 2020, 05:32:07 PM »
Got it, thanks for the help.
« Reply #9 on: July 24, 2020, 03:04:09 PM »
This is a long read but you'll appreciate the detail when you're installing it. You'll want to print this out.  It's at least a long day, and one of the most complex installs I've done.  But it goes easy enough if you follow Bob's guide and just do it.  Adjust as needed to work with your bike.  And on a I/S, you can put the main control unit in the fairing.  I had to cram mine under the seat.  The Rostra electronic CC is more reliable than the audiovox vacuum system.  I also have the Brakeaway throttle lock on all my Valks and the Magna.  It's very nice but is not a cruise control.
I added my info after BobB's well written guide.  BTW It's better usability to put the cruise control panel on the left side if you make room.
You'll need more parts than in the ebay pic.  The speed signal generator, extra magnets, the cruise control dash mount panel.  I bought mine in a kit from Rostra IIRC.  BTW they don't want to hear you're putting it on a bike.  Support stops then.  Tell a white lie if they ask.
http://www.valkyrieforum.com/bbs/index.php/topic,86066.0.html
« Last Edit: July 24, 2020, 03:31:02 PM by MarkT » Logged
RUDE DOG - Steelers
« Reply #10 on: July 25, 2020, 10:52:34 PM »
Awesome, Thanks Mark.
Brewmaster
« Reply #11 on: May 18, 2021, 02:35:36 PM »
I know this is an old topic but did anyone ever get the Rostra to work with the IS Speed Sensor? I'd rather not install the magnet kit if I can avoid it.
Kelvin Krastel
99 IS
2000 Tourer.
Moxxican
Moxee, Wa.
« Reply #12 on: May 27, 2021, 08:43:05 PM »
Jersey was working on a plug-and-play kit that would use the IS speed sensor. Don't know if he got anywhere with it. I ended up using the Rostra pickup, with an aluminum bracket I made to mount it behind the stock speed sensor, and some stick-on magnets from home depot. If you didnt know, you'd think it was stock. I can send you pics and more info, if you're interested.
Moxxican
Jersey
VRCC #37540
Southern Maryland
« Reply #13 on: May 28, 2021, 04:39:57 AM »
Moxxican
I experimented with a few approaches, but nothing seemed better than just using a resistor to tap into the VSS wire.   I use a 720k resistor on mine, but other have found a 470k resistor works.  What that suggests is the specific size might need to be verified.  Would suggest starting with something like 560k or similar.  See how it goes.
Jersey
