December 30, 2025, 04:35:57 PM
MCCruise issues
Topic: MCCruise issues (Read 1166 times)
PuyallupValk
MCCruise issues
August 17, 2020, 09:56:49 PM »
Hello, All! My 99 I/S has a MCCruise installed. It doesn't engage and in speaking with Tony (co-founder of MCCruise), he suggested I clean the solenoids that pull vacuum...so I did. The vacuum solenoid was indeed stuck. Not anymore. The problem still exists where I can't seem to get any response from the 'computer'...the red LED doesn't come on under any circumstances. Does anyone out there happen to have an early 'computer' for a MCCruise system that they're willing to part with? Thanks in advance.
Moxxican
Moxee, Wa.
Re: MCCruise issues
August 23, 2020, 09:04:32 PM »
I have two of them that came with a used McCruise I bought. I just bought it for the switch unit, but I ended up using the Rostra switch instead. PM me and I'll hook you up.
Re: MCCruise issues
August 24, 2020, 10:18:22 AM »
This comment won't help your issue, but for others thinking of installing a true cruise control as opposed to a throttle lock. Potential vacuum issues is why I chose to install a Rostra electronic cruise instead of the McCruise. Both have the same source, I think. Vacuum systems use diaphrams and some other analog parts rather than mostly digital parts. The diaphrams will eventually crack and leak especially in a dry environment like here. After installing my Rostra some years ago I've had no issues other than I replaced a standard automotive 5-pin relay once. Here's BobB's writeup followed by my comments on the Rostra install.
http://www.valkyrieforum.com/bbs/index.php/topic,86066.0.html
PuyallupValk
Re: MCCruise issues
August 24, 2020, 12:20:15 PM »
I believe the current version of the MCCruise uses electronic actuation as well...just sayin...
PuyallupValk
Re: MCCruise issues
August 24, 2020, 12:21:53 PM »
Quote from: Moxxican on August 23, 2020, 09:04:32 PM
You have a PM, sir!
=> InZane XXV
