November 12, 2025, 11:43:24 AM
Left handlebar grip removal
Topic: Left handlebar grip removal (Read 1638 times)
john sweet
April 07, 2021, 06:08:45 AM »
How do I remove the left handlebar grip on a 1997 Valkyrie? Thanks, John,
h13man
Indiana NW Central Flatlands
Re: Left handlebar grip removal
April 07, 2021, 07:48:17 AM »
Gentl
y pry against the housing and twist the grip back and forth or remove the housing and pry the grip open and shoot WD40 in it and repeat.
vanagon40
Greenwood, IN
April 07, 2021, 08:09:47 AM »
Search "grip removal" and you will find a lot of helpful threads.
For example:
http://www.valkyrieforum.com/bbs/index.php/topic,29620.0.html
I use compressed air.
April 07, 2021, 08:41:31 AM »
If you can't use compressed air, the best method is to slide an icepick under and sister up the long skinny nozzle of a solvent (Gummout carb cleaner) next to the icepick and spray. Do it several times, and it should come right off. If you don't need to save it, cut it off.
=> InZane XXV
