February 12, 2026, 01:13:59 AM *
Author Topic: Timing belt tensioner pulley rebuild plates - MD Tech  (Read 6927 times)
mello dude
Dayton Ohio
« on: March 25, 2022, 03:49:01 PM »
Hey - Following up from this topic....
http://www.valkyrieforum.com/bbs/index.php/topic,121068.0.html
---->I am in process to have the quotes for laser cut parts and would like to know who would want this.
Debating about the material for it. The stocker is a steel piece, but type is unknown and there's no corrosion on it. So, I am looking at cold rolled steel and then 316 stainless. - I'm a tiny bit conserned about gavanic interface corrosion with the SS, but thinking to add a .005 Mylar insulator washer to the interface if I go that way. And possibly with the Cold Rolled steel, I would powder coat it.. (my own parts only -- I could do the batch if asked)
The thing is, once you have the tensioner plates, when the time comes around to replace the OEM tensioner, you are now looking at a 40 dollar job, buy new bearings from Amazon, instead of a $180 to $200 job depending on who you buy the OEM part from.  Then, maybe later as a maintenance item say 50k to 60k miles, you just replace the bearings and reuse the tensioner plates.  And.. will be far better than the OEM overpriced cheap assembly.
---(An assembly note: It will go together with a M10 x 1.25 x 25mm Hex Flange head bolt & Nut. Grade 10.9 )
(2 cents on me, I am an automotive engineer by trade. I always overthink and overkill stuff.  So I have made laser cut parts before typically first because I want that part for my bike, and make more to spread out the cost. Then sell the parts to other guys and try to break even. )
« Last Edit: September 10, 2023, 11:53:00 AM by mello dude » Logged
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: March 25, 2022, 04:36:34 PM »
I'll take at least one set. Valker1@hotmail.com
« Last Edit: March 25, 2022, 05:19:57 PM by Valker » Logged
mello dude
Dayton Ohio
« Reply #2 on: March 25, 2022, 05:01:27 PM »
I'll take some. Vallker1@hotmail.com
Oh, I forgot to ask,  obviously 2 is a set. Mention number of sets....
Thxz
« Last Edit: August 14, 2022, 09:51:51 AM by mello dude » Logged
« Reply #3 on: March 25, 2022, 05:09:14 PM »
I think you might have more takers if you were to sell the complete tensioner put together. I like to do the work on my bike, and would probably rebuild mine myself. But a lot of guys don’t, and would prefer buying the complete unit. (Just an idea)  cooldude
mello dude
Dayton Ohio
« Reply #4 on: March 25, 2022, 06:09:16 PM »
That's a thought, if consensus prefers that way... rather not, price starts to go up... but I would if needed.
« Last Edit: August 14, 2022, 09:52:32 AM by mello dude » Logged
luftkoph
E U.P. Mich
« Reply #5 on: March 25, 2022, 09:16:10 PM »
SS or steel doesn’t matter to me, nor the need for powder coating, I’ll take 2 sets
Some day never comes
Mooskee
Southport NC
« Reply #6 on: March 26, 2022, 07:19:44 AM »
I will take 1 set.
« Reply #7 on: March 26, 2022, 10:46:13 AM »
"Debating about the material for it. The stocker is a steel piece, but type is unknown and there's no corrosion on it. So, I am looking at cold rolled steel and then 316 stainless. - I'm a tiny bit conserned about gavanic interface corrosion with the SS, but thinking to add a .005 Mylar insulator washer to the interface if I go that way. "
It has been about 38 years since I had my corrosion class while getting my metallurgical engineering degree, but I doubt there is much difference as far as galvanic corrosion between stainless and plain carbon steel.  If I understand your concern properly. you are worried about corrosion between the mounting plate and the tensioner pully?  Stainless and carbon steel are both iron basically, so I would think there would be little to no difference in galvanic potential between the two parts.  The tensioners mount via a steel bolt to the aluminum cylinder case, there is a difference in galvanic potential between aluminum and steel, but since we don't see corrosion between the OEM tensioners and the cylinder case, I doubt you need be concerned.
mello dude
Dayton Ohio
« Reply #8 on: March 26, 2022, 12:01:17 PM »
Skinhead, just overthinking the steel/aluminum interface....thanks for your expertise, awesome post. cooldude
« Last Edit: August 14, 2022, 09:53:18 AM by mello dude » Logged
« Reply #9 on: March 26, 2022, 12:13:34 PM »
No Problem.  In designing something, it is good to look at all possibilities for failure, and if you can confidently eliminate them, the greater your chances of a successful design.
mello dude
Dayton Ohio
« Reply #10 on: March 26, 2022, 03:20:17 PM »
Yup, agree... that's what I do for a living...  Smiley
« Last Edit: August 14, 2022, 09:54:02 AM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #11 on: May 31, 2022, 07:01:27 PM »
316 stainless steel material with  Grade 10.9 fasteners
OEM piece on left for reference
http://www.valkyrieforum.com/bbs/index.php/topic,121914.0.html
« Last Edit: August 14, 2022, 10:00:01 AM by mello dude » Logged
luftkoph
E U.P. Mich
« Reply #12 on: May 31, 2022, 07:44:40 PM »
Nice looking
mello dude
Dayton Ohio
« Reply #13 on: June 26, 2022, 10:19:27 AM »
Anybody do an install yet?  Smiley
Mooskee
Southport NC
« Reply #14 on: June 26, 2022, 03:48:37 PM »
Sorry, mine are sitting in the shop waiting till one of the bikes needs them.
OttawaWill
Ottawa, Ontario, Canada
« Reply #15 on: June 26, 2022, 04:44:25 PM »
Im interested in taking a set. Shipping to Canada??? Ottawa, Ontraio.
mello dude
Dayton Ohio
« Reply #16 on: June 26, 2022, 06:04:16 PM »
Check PM plz... Smiley
Tazman11
Idaho
« Reply #17 on: June 26, 2022, 06:54:59 PM »
Received mine. Looks like quality kit. I will be installing mine this winter.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #18 on: July 31, 2022, 01:38:06 PM »
Does anyone have the bearing number that would be needed? Maybe I’m just overlooking it.
Tazman11
Idaho
« Reply #19 on: July 31, 2022, 02:21:11 PM »
https://www.amazon.com/Gates-T42015-Idler/dp/B000IVPEZM?pd_rd_w=Dq2ZS&content-id=amzn1.sym.bc622850-a717-4d94-96c3-7cc183488298&pf_rd_p=bc622850-a717-4d94-96c3-7cc183488298&pf_rd_r=BBXV376WKAZF1HESMCG4&pd_rd_wg=0xzha&pd_rd_r=19d6a439-35d5-4098-9df0-ed403e928614&pd_rd_i=B000IVPEZM&psc=1&ref_=pd_bap_d_rp_107_t
Here is what I ordered.
mello dude
Dayton Ohio
« Reply #20 on: July 31, 2022, 03:04:48 PM »
That's was I ordered too......it's really a Hyundai part made by Gates in Korea. (The country of origin on Amazon lists China,  but its wrong...).... Interesting that all the comments are Valkyrie or Gold Wing guys
« Last Edit: July 31, 2022, 03:24:59 PM by mello dude » Logged
Bagger John - #3785
« Reply #21 on: July 31, 2022, 04:22:18 PM »
I'm in for two sets.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #22 on: August 01, 2022, 08:21:56 AM »
Mike,
Already installed a week after receiving.  All worked well.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
mello dude
Dayton Ohio
« Reply #23 on: August 01, 2022, 09:06:07 AM »
Mike,
Michael
That's great, thank you for letting me know. Any photos ?
« Last Edit: August 14, 2022, 09:49:35 AM by mello dude » Logged
Steven Bumpus
Madison, AL
« Reply #24 on: August 01, 2022, 01:43:41 PM »
I'd like to get a set for winter maintenance.
2002 Shadow
2011 TriGlide
Umbra
« Reply #25 on: August 05, 2022, 04:24:09 AM »
I would like to get at two sets
mello dude
Dayton Ohio
« Reply #26 on: August 05, 2022, 12:54:46 PM »
Check PM plz  Smiley
longrider
Vernon, B.C. Canada
« Reply #27 on: August 12, 2022, 03:04:22 PM »
I would be in for 1 set   Will you take paypal.
mello dude
Dayton Ohio
« Reply #28 on: August 12, 2022, 03:37:42 PM »
Check PM plz.....yes, PayPal is preferred.  Could take a check if needed.
« Last Edit: September 16, 2022, 02:52:09 PM by mello dude » Logged
Jruby38
Oxford Mass.
« Reply #29 on: August 12, 2022, 03:40:50 PM »
I will take a set. How much $, and how do I pay?
mello dude
Dayton Ohio
« Reply #30 on: August 12, 2022, 07:06:49 PM »
Check PM plz.
« Last Edit: August 13, 2022, 11:00:58 AM by mello dude » Logged
Rosie
Clintonville WI 54929
« Reply #31 on: August 14, 2022, 12:17:54 PM »
How much for a set and how do i pay?
1999 Valkyrie tourer
2003 Valkyrie standard
mello dude
Dayton Ohio
« Reply #32 on: August 14, 2022, 12:52:57 PM »
Check PM plz.....
6adan
Zip City, Alabama
« Reply #33 on: August 16, 2022, 05:41:29 AM »
  I would thank these would fit the 1500 Goldwing too. You might want to go to Steve Sanders Forum and let them know about them. I am thanking they will also work on all of the wings from 1000 to 1500, haven't been able check that but they all look alike. Please send me a price also.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
mello dude
Dayton Ohio
« Reply #34 on: August 16, 2022, 12:34:33 PM »
Thank you for the heads up. Plz check PM.
« Last Edit: August 17, 2022, 04:17:05 PM by mello dude » Logged
longrider
Vernon, B.C. Canada
« Reply #35 on: August 18, 2022, 04:49:39 PM »
Are you able to supply bolts?, Bearings?.    If not what size bolts are you using?
Warren
mello dude
Dayton Ohio
« Reply #36 on: August 18, 2022, 05:43:30 PM »
Warren
Bolts are included in a set, they are Hex Flange M10 x 1.25 thread, x 25mm long,  And matching nut, as in the photo above.
The bearings can be purchased from Amazon. If you want me to supply, we should take this to a PM.
« Reply #37 on: August 19, 2022, 11:38:07 AM »
Mike, I finally got around to installing those new tension pulley backing plates. Looks kind spiffy!  cooldude  Thanks for doing this, however I now have an old set of backing plates with bolts. Guess I'll hang onto them for now.
mello dude
Dayton Ohio
« Reply #38 on: August 19, 2022, 12:22:49 PM »
Awesome  cooldude  - Thanks John for posting this up. I admit I do get a bit of a kick when I see my parts on guys bikes.
« Last Edit: August 19, 2022, 03:43:44 PM by mello dude » Logged
Mooskee
Southport NC
« Reply #39 on: August 19, 2022, 07:03:16 PM »
I agree it looks spiffy indeed. Nice.
