November 11, 2025, 11:07:53 AM *
Author Topic: Tranny question  (Read 1772 times)
GWS
Central New York
« on: January 09, 2024, 01:35:13 PM »
I know the Valkyrie engine is a tweaked version of the Goldwing engine. What about the transmission? Same as the Goldwing, or are there little differences in bottom end, top end gear ratios, etc?
Thanks.
« Reply #1 on: January 09, 2024, 05:11:22 PM »
I'm glad this question is about motorcycles.   Grin
« Reply #2 on: January 09, 2024, 05:39:39 PM »
from my post  https://www.valkyrieforum.com/bbs/index.php/topic,29276.0.html
According to Fred Rau in motorcycle consumer news june 05 article.
GL1500 3rd 1.272, 4th .964, 5th .758.
Valkyries 3rd 1.291, 4th 1.00, 5th .805.
 1st and 2nd are the same all GL1500 engines.
early than '97 gear sets will not work in the valkyrie, the GW shafts are smaller from my understanding and other posts from a few yrs ago. The parts fiches seem to bear this out.
in '97 all GL1500 engines received all the same clutch plates, prior to that a few plates were not the same as the others.
Goldwing gears have always been straight cut. Don't know about the GL1800.
http://www.goldwingfacts.com/forums/forum1/101096.html
http://www.valkyrieforum.com/bbs/index.php/topic,27706.0.html
from the June '05 issue of motorcycle consumer news, by Fred Rau. He was the editor of Wing World magazine in '87, the news letter of the largest Gold Wing organization, the Gold Wing Road Riders Association (GWRRA), and now contributes to MCN.
"in '97 the GW recieved a fairly major upgrade that was, oddly enough not heralded by Honda. Honda quietly lifted the Valkyrie's main bearings, pistons, piston rings, con-rod bolts and valve springs into the '97 Wing, along with the smoother-shifting Valkyrie gearbox and the entire final drive unit. In addition, the clutch was strengthened, also."
Also from the article, 1) '88 through '94, 4th and 5th gear wear out at around 100k miles, gears were upgraded in '95 and newer. Also, shift forks wear out from riders resting their toe on the shift lever while riding. their experts warned that the use of heel-toe shifters is also responsible for shift fork damage, as your heal puts much more force on the shifter than your toe would. 2) speedo cable should be lubed every front tire change other wise they break at 100k miles. 3) final drive splines, maintenance should be done IAW honda service bulletin 97991-MAH-305.
