April 29, 2026, 12:11:10 PM *
Author Topic: New radiator grill  (Read 1526 times)
Ghillie
Garland, TX
« on: February 28, 2010, 08:34:44 PM »
I got a new grill form Valk Bling at Christmas. is there a trick to getting it perfectly flush on install. There is a small difference at the edges and the forks are bumping it when turned all the way.
When the people fear government, there is tyranny. When government fears the people, there is liberty.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: February 28, 2010, 09:00:38 PM »
Someone else had a similar complaint recently: http://www.valkyrieforum.com/bbs/index.php/topic,11901.0.html
Don't know if it's the same issue/solution or not.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #2 on: March 01, 2010, 04:53:20 AM »
Let us know if you find a solution. Mine bump at full stop too, but that only happens when I'm in the
parking lot and when I'm fully locked up doing power slides...
After almost three years, there's a tiny mark in the paint (I have the red ones, not the chrome ones) at
the top edge of the cover, and no other known side effects...
I've got different side covers, and the bolt stays exposed, and always kept tight, so that didn't
fix it for me...
godfire
Republic of Texas
« Reply #3 on: March 01, 2010, 06:18:33 AM »
Which one did you get? cooldude
My forks rest on the top when I turn all the way.
My end caps must be loose, because there is some play in the end cap, cover, top cap assembly.
When I turn hard it all moves back about 1/8".  I just rolled with it.
You can take a look at the next wrench party.
Ride Safe
Ride Often
Ghillie
Garland, TX
« Reply #4 on: March 01, 2010, 01:00:56 PM »
sounds like we are talking about the same thing, it's just enough to be annoying
